on 21-03-2023 15:34
my hub 3 has been working in modem mode for some time.
once I install the new hub 5, do I simply change that to modem mode? No other steps required?
im mindful that I don’t want anything else to go wrong in the process.
any help would be appreciated.
thanks
on 21-03-2023 15:51
on 21-03-2023 16:32
on 21-03-2023 16:35
Make sure you power on the Hub5 as the last thing you do. This is just in case your WAN IP has changed.
on 21-03-2023 16:36
Thank you
ive currently got two routers set up as a mesh off the hub 3. Would I need to do anything with the settings on these routers or, just as you’ve detailed on the Hub 5 ?
on 23-03-2023 18:14
Hi @Cruzeroo7,
Welcome to our community forums and thank you for your first post.
As mentioned by our community, after setting up the new hub, you should be able to put the hub in router mode. In regards to the other hubs, as this is third part equipment we would be unable to best advise.
Please let us know if you need any further help.
on 23-03-2023 18:47
@Cruzeroo7 wrote:ive currently got two routers set up as a mesh off the hub 3. Would I need to do anything with the settings on these routers or, just as you’ve detailed on the Hub 5 ?
You need the hub in modem mode and the main router connected to it by its WAN port to be in router mode (as it's your DHCP server). Any routers downstream of the main router should not also be in router mode.
on 23-03-2023 21:58
