on 20-07-2021 17:21
Hi community,
I am on my end of any solutions here.
My internet started to keep drop in the last 2 months, it worked smoothly before and without any loss. I am experiencing everyday drops ( working from home/ losing my connection) also gaming and kicked out from the sever at different times of the day
I tried already to check cabling, restarted the router several times, factory reset. I thought it was probably that I've got around 15 wireless devices connected to my HUB 3.0 and it cannot keep it up, but this was not the case, because I bought a Netgear Nighthawk XR1000 , placed the HUB 3.0 into modem mode, and it still happening ... I am at the edge of my powers in here as I don't know what to do anymore. Called VirginMedia several times, eChat aslo...begging for an engineer visit, but I was just told that "no issues found in your area" etc .
I placed back the HUB 3.0 in router mode so I could create a monitor via thinkbroadband so I could share with you.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/92791dc558519af57bfa0e5a00446380ff...
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/92791dc558519af57bfa0e5a00446380ff4cf312"><img alt="My Broadband Ping - Virgin Media Denis" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/92791dc558519af57bfa0e5a00446380ff4cf312.png" /></a>
Also I will paste here the logs from the Virgin Media 3.0HUB.
TimePriorityDescription20/07/2021 15:58:51noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;20/07/2021 09:59:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;20/07/2021 09:59:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2021 19:28:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2021 19:28:23criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2021 03:17:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2021 02:56:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2021 02:56:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;19/07/2021 01:11:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 22:48:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 22:35:52criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 22:08:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 21:25:55criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 21:15:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 21:05:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 20:53:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 20:52:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 20:25:11Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 20:24:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/07/2021 20:20:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Help me get an engineer site visit please!
I will post Upstream and Downstream levels in the next post as it says I reached 20 000 characters for now
on 03-08-2021 18:23
1 | 203000000 | 4.9 | 38 | 256 qam | 9 |
2 | 139000000 | 5.5 | 38 | 256 qam | 1 |
3 | 147000000 | 5.8 | 38 | 256 qam | 2 |
4 | 155000000 | 5.8 | 38 | 256 qam | 3 |
5 | 163000000 | 5.6 | 38 | 256 qam | 4 |
6 | 171000000 | 5.5 | 38 | 256 qam | 5 |
7 | 179000000 | 5.4 | 38 | 256 qam | 6 |
8 | 187000000 | 5.4 | 38 | 256 qam | 7 |
9 | 195000000 | 5.1 | 38 | 256 qam | 8 |
10 | 211000000 | 4.6 | 38 | 256 qam | 10 |
11 | 219000000 | 4.3 | 38 | 256 qam | 11 |
12 | 227000000 | 3.9 | 38 | 256 qam | 12 |
13 | 235000000 | 3.2 | 38 | 256 qam | 13 |
14 | 243000000 | 2.7 | 38 | 256 qam | 14 |
15 | 251000000 | 3.2 | 38 | 256 qam | 15 |
16 | 259000000 | 3.5 | 38 | 256 qam | 16 |
17 | 267000000 | 3.5 | 38 | 256 qam | 17 |
18 | 275000000 | 3.2 | 38 | 256 qam | 18 |
19 | 283000000 | 3.2 | 38 | 256 qam | 19 |
20 | 291000000 | 3 | 38 | 256 qam | 20 |
21 | 299000000 | 3 | 38 | 256 qam | 21 |
22 | 307000000 | 3 | 38 | 256 qam | 22 |
23 | 315000000 | 2.7 | 38 | 256 qam | 23 |
24 | 323000000 | 2.9 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 8839 | 11382 |
2 | Locked | 38.6 | 67079 | 27185 |
3 | Locked | 38.6 | 14210 | 14972 |
4 | Locked | 38.9 | 27602 | 16182 |
5 | Locked | 38.9 | 61401 | 22731 |
6 | Locked | 38.9 | 9778 | 12636 |
7 | Locked | 38.9 | 45348 | 15880 |
8 | Locked | 38.9 | 17806 | 12274 |
9 | Locked | 38.9 | 9096 | 12100 |
10 | Locked | 38.9 | 8566 | 11396 |
11 | Locked | 38.9 | 8565 | 11241 |
12 | Locked | 38.6 | 9196 | 10767 |
13 | Locked | 38.9 | 9366 | 10523 |
14 | Locked | 38.6 | 8633 | 10777 |
15 | Locked | 38.6 | 8469 | 10689 |
16 | Locked | 38.9 | 8297 | 10312 |
17 | Locked | 38.9 | 8534 | 10325 |
18 | Locked | 38.6 | 8342 | 10217 |
19 | Locked | 38.9 | 8214 | 9784 |
20 | Locked | 38.9 | 8342 | 10162 |
21 | Locked | 38.6 | 8450 | 10371 |
22 | Locked | 38.9 | 8135 | 9993 |
23 | Locked | 38.9 | 8008 | 8930 |
24 | Locked | 38.9 | 8017 | 9780 |
1 | 60299995 | 47 | 5120 | 64 qam | 6 |
2 | 46200140 | 46 | 5120 | 64 qam | 8 |
3 | 53700000 | 46.5 | 5120 | 64 qam | 7 |
4 | 39400000 | 45.5 | 5120 | 64 qam | 9 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 12 | 0 |
on 03-08-2021 18:57
Hi @DenisC,
Thanks for posting your updates on the ongoing issues that you're having.
I have looked into your account and the local area and cannot see any issues that would be causing the problem to be still ongoing. All the levels are in specification for a stable connection but clearly you are still having issues since the visit.
Have you tried a pin hole reset of your hub, since the engineer visit, If not, please could you try this and let us know if that makes any difference at all to your connection?
Steven_L
on 03-08-2021 19:05
Many thanks Steven for your quick reply.
I think pin hole reset will not change everything as the Hub is new, replaced 1 week ago by VM engineer. Will give it a shot anyway, but according to the logs are the same errors as with the old one.
on 03-08-2021 19:37
Please keep us posted on how you get on with the pinhole reset.
Zoie
on 04-08-2021 09:01
Hi @Zoie_P , @Steven_L !
I pin hole reset the VM hub yesterday right after your post
As we can see in the BQM link, did not resolve anything 😞
https://www.thinkbroadband.com/broadband/monitoring/quality/share/16d15401f278c65017753c57fb7cbbae19fc3f35
The big red line at 19:00 pm is when I pin hole reset it
Strange is that it can be stable for 10hours....or 2 hours...etc and then suddenly intermittent. When starts to flap a reboot is not fixing it, it fixes by itself either after hours, or minutes. That's why I pinpoint that the issue is not with my hardware equipment as was already replaced, it must be deeper
on 04-08-2021 11:12
Hello @DenisC.
Thank you for this update, we may need to send an engineer round.
I will send you a private message so I can get this arranged.
Many thanks,
on 04-08-2021 12:15
Hello @DenisC,
Thank you for talking to me in a private message today.
I am glad we have a plan in place to fix this!
I look forward to your update once the engineer has been to your home.
Have a lovely day and take care for now.
Many thanks,
on 06-09-2021 12:16
Hi all!
The engineer visit was on 6th August. He did not change anything (cables or hardware) as I described to him what the previous engineer have done (previous engineer changed cables/router etc) He said that the problem might be more "deep" as the internet are coming thorugh around 3 feeds until is reaching my house, he also said that will open a case with the Network team to monitor my connection (something similiar with what thinkbroadband does I think) as I show him also my thinkbroadband stats.
Since then, it is 1 month and nobody has reached me with any status from VirginMedia, although the engineer said that will be a phone back call in 10 days...
Can this be sorted, please? There are months already and I still can't rely on my internet connection. I still work from home, and already have problems at work due to going off in the middle of meetings very often.
Below is my live graph and I will post also downstream/ upstream/ network logs
https://www.thinkbroadband.com/broadband/monitoring/quality/share/16d15401f278c65017753c57fb7cbbae19...
on 06-09-2021 12:19
1 | 139000000 | 5.8 | 36 | 256 qam | 1 |
2 | 147000000 | 6 | 36 | 256 qam | 2 |
3 | 155000000 | 6.3 | 37 | 256 qam | 3 |
4 | 163000000 | 6 | 37 | 256 qam | 4 |
5 | 171000000 | 6 | 37 | 256 qam | 5 |
6 | 179000000 | 5.6 | 37 | 256 qam | 6 |
7 | 187000000 | 5.8 | 37 | 256 qam | 7 |
8 | 195000000 | 5.4 | 37 | 256 qam | 8 |
9 | 203000000 | 5 | 37 | 256 qam | 9 |
10 | 211000000 | 4.8 | 37 | 256 qam | 10 |
11 | 219000000 | 4.3 | 37 | 256 qam | 11 |
12 | 227000000 | 4 | 37 | 256 qam | 12 |
13 | 235000000 | 3.2 | 37 | 256 qam | 13 |
14 | 243000000 | 3 | 37 | 256 qam | 14 |
15 | 251000000 | 3 | 37 | 256 qam | 15 |
16 | 259000000 | 3.5 | 37 | 256 qam | 16 |
17 | 267000000 | 3.5 | 37 | 256 qam | 17 |
18 | 275000000 | 3.4 | 37 | 256 qam | 18 |
19 | 283000000 | 3.2 | 37 | 256 qam | 19 |
20 | 291000000 | 3.2 | 37 | 256 qam | 20 |
21 | 299000000 | 3.2 | 37 | 256 qam | 21 |
22 | 307000000 | 3.2 | 37 | 256 qam | 22 |
23 | 315000000 | 3 | 37 | 256 qam | 23 |
24 | 323000000 | 2.7 | 37 | 256 qam | 24 |
1 | Locked | 36.3 | 2440718 | 285578 |
2 | Locked | 36.3 | 780529 | 128079 |
3 | Locked | 37.3 | 1323578 | 132289 |
4 | Locked | 37.3 | 2194913 | 369507 |
5 | Locked | 37.3 | 413799 | 57461 |
6 | Locked | 37.3 | 1282278 | 120238 |
7 | Locked | 37.6 | 319018 | 52114 |
8 | Locked | 37.6 | 74790 | 45368 |
9 | Locked | 37.3 | 63852 | 43241 |
10 | Locked | 37.3 | 76964 | 40664 |
11 | Locked | 37.6 | 75786 | 41092 |
12 | Locked | 37.3 | 72482 | 39600 |
13 | Locked | 37.3 | 80196 | 39240 |
14 | Locked | 37.3 | 68825 | 37879 |
15 | Locked | 37.3 | 56404 | 35242 |
16 | Locked | 37.3 | 52477 | 34571 |
17 | Locked | 37.3 | 59767 | 34603 |
18 | Locked | 37.6 | 53051 | 34353 |
19 | Locked | 37.6 | 46437 | 31688 |
20 | Locked | 37.6 | 43948 | 31063 |
21 | Locked | 37.3 | 47570 | 32298 |
22 | Locked | 37.6 | 42415 | 31165 |
23 | Locked | 37.6 | 40474 | 30002 |
24 | Locked | 37.6 | 42440 | 29593 |
1 | 60300000 | 47.3 | 5120 | 64 qam | 6 |
2 | 46200044 | 46 | 5120 | 64 qam | 8 |
3 | 53700069 | 46.8 | 5120 | 64 qam | 7 |
4 | 39399995 | 45.8 | 5120 | 64 qam | 9 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 30 | 0 |
3 | ATDMA | 0 | 0 | 21 | 0 |
4 | ATDMA | 0 | 0 | 3 | 0 |
06/09/2021 11:00:30 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 10:59:52 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 10:59:52 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 10:59:50 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 10:59:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 10:59:45 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 10:59:43 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 10:59:43 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/09/2021 10:59:42 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 06-09-2021 13:16
