on 21-08-2021 17:21
We had internet installed on Thursday. Speeds have been well below what was advertised. Today, the internet is intermittent and the hub is showing an orange light. Having read similar posts and FAQs, this should not happen and can only mean a fault with the hardware. I have tried several factory resets and the problem remains. Please advise.
on 21-08-2021 17:25
Is the speed you measured over WiFi or ethernet cable? If over WiFi, test again with a cable connection.
on 21-08-2021 17:34
Wi-fi. This does not answer the question re the orange light.
on 21-08-2021 17:38
the power light can be many shades - white - cream and orangish - orang does not mean a fault
post some info from the hub
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
if its an earlier hub button is top right
on 21-08-2021 17:40
@Daveyclak wrote:Wi-fi. This does not answer the question re the orange light.
WiFi speeds are not guaranteed. What speeds do you get with an ethernet connection?
on 21-08-2021 17:59
There are no options other than to sign in and I cannot do this as it rejects the password. The light is definitely orange and can in no way be interpreted as a shade of white/yellow. This has come up on a different thread and a faulty hub was indicated.
on 21-08-2021 18:02
You don't need to log in. The link is on the screen below the sign-in box.
on 21-08-2021 18:08
There is no link below the sign in box.
21-08-2021 18:12 - edited 21-08-2021 18:18
Hi Daveyclak
I'm not sure but perhaps if you've never logged into the hub settings before you won't be able to access the details requested.
You should be able to sign in using the settings password (printed on the base of the hub), not the wifi password
on 21-08-2021 18:15
