on 12-04-2018 10:45
Hub 3.0 settings password (which is printed on the bottom of the router) isn't working. Does Virgin reset this with a different default password and if so how do I get it?
11-10-2018 11:02 - edited 11-10-2018 11:03
@James_W wrote:Updates made last night should have resolved this issue for those of you affected.
A simple reboot is all that should now be required.
I’m sorry but rebooting has made absolutely ZERO difference - the Setting Password (the 8 digit number shown on the bottom of my Hub 3) is STILL not being accepted (as I said before, I have NEVER changed this number).
My Hub 3 has software version: 9.1.116.608
WHY IS THIS NOT WORKING???
11-10-2018 13:00 - edited 11-10-2018 13:00
@deans6571 wrote:WHY IS THIS NOT WORKING???
Why are you so reluctant to do the pinhole reset with a twist (message 12) - it will take all of 5 minutes to reinput ssid changes? A lot of people >10 have done this this week and its sorted similar problems
on 07-11-2018 19:22
I can vouch for the solution in message 12.
More specifically:
1) stick a pin in the reset hole for a good 20 or 30 secs but DON'T switch the hub off and on
2) Connect to the hub admin page (once it is available) and it should ask you to enter the default password and then change it
After that I can login fine. If you're worried about losing new password then stick it on the bottom of your hub. But you can always do the reset again.
Apparently VM support know nothing about this solution, after 20 min wait couldn't offer anything other than replacing the hub. Nice to know that the customers know more than their staff.
on 01-12-2018 17:34
Hi i`m with the same problem, was this applied to all users or only to who complained?
on 01-12-2018 17:54
Actually my case solved by leaving the reset button pressed for 60 seconds with the router on, the hub will start flickering but after all the 60s i have release the reset button and will request to setup the language and the new password.
on 21-01-2019 13:27
....still not working even though I have tried deleting and reinstalling the app....
Why must the so called' fix' (which isn't really a fix anyway) involve me resetting my Hub 3 back to factory settings and me then spending the next half hour going through and renaming all the SSIDS and inputting all the wifi password again from scratch?
There is obviously an underlying issue if the app is saying that my settings password is incorrect when I know for a fact that it is 100% CORRECT.....
on 08-02-2019 18:03
I have the same problem too and I ain't going tech support for it.
I hope somebody can identify a solution and post on here.
I would not only have to do ids and passwords, I would have to do all the macs for mac filtering, and there's a bug with that too, in that after a few entries you have to choose a mac two above the one you actually want populated in the filter list. I have over twenty in the list. Can't be bothered with that.
Is there any other way to connect to the 'Connect' app, because there flaming well should be!
on 08-02-2019 18:20
Hi pbarrett, sorry to hear you're having issues.
Have you tried a reset on the router?
Kind regards,
on 08-02-2019 18:54
I might get around to it, possible, but as mentioned above......
"I would not only have to do ids and passwords, I would have to do all the macs for mac filtering, and there's a bug with that too, in that after a few entries you have to choose a mac two above the one you actually want populated in the filter list. I have over twenty in the list. Can't be bothered with that."
on 08-02-2019 19:02
No worries, apologies for that. Please let me know how you get on.
Kind regards,
