on 05-08-2021 18:25
I have had virgin for nearly two years, but last week or so I am having wifi drop outs (I've written this message three times and it dropped out before I posted it every-time)! I have no idea what to do. Included Downstream, Upstream and Network Log. Can anyone help me?
1 | 226750000 | 7 | 40 | 256 qam | 12 |
2 | 138750000 | 8.5 | 40 | 256 qam | 1 |
3 | 146750000 | 8.3 | 40 | 256 qam | 2 |
4 | 154750000 | 8.3 | 40 | 256 qam | 3 |
5 | 162750000 | 7.9 | 40 | 256 qam | 4 |
6 | 170750000 | 7.9 | 40 | 256 qam | 5 |
7 | 178750000 | 7.6 | 40 | 256 qam | 6 |
8 | 186750000 | 7.6 | 40 | 256 qam | 7 |
9 | 194750000 | 7.6 | 40 | 256 qam | 8 |
10 | 202750000 | 7.5 | 40 | 256 qam | 9 |
11 | 210750000 | 7.5 | 40 | 256 qam | 10 |
12 | 218750000 | 7 | 40 | 256 qam | 11 |
13 | 234750000 | 6.9 | 40 | 256 qam | 13 |
14 | 242750000 | 6.9 | 40 | 256 qam | 14 |
15 | 250750000 | 7 | 40 | 256 qam | 15 |
16 | 258750000 | 6.6 | 40 | 256 qam | 16 |
17 | 266750000 | 7 | 40 | 256 qam | 17 |
18 | 274750000 | 6.6 | 40 | 256 qam | 18 |
19 | 282750000 | 6.9 | 39 | 256 qam | 19 |
20 | 290750000 | 7 | 38 | 256 qam | 20 |
21 | 298750000 | 7 | 38 | 256 qam | 21 |
22 | 306750000 | 7.1 | 40 | 256 qam | 22 |
23 | 314750000 | 7 | 40 | 256 qam | 23 |
24 | 322750000 | 7 | 40 | 256 qam | 24 |
1 | Locked | 40.9 | 10 | 0 |
2 | Locked | 40.9 | 5 | 0 |
3 | Locked | 40.9 | 22 | 0 |
4 | Locked | 40.9 | 21 | 0 |
5 | Locked | 40.9 | 28 | 0 |
6 | Locked | 40.9 | 21 | 0 |
7 | Locked | 40.9 | 21 | 0 |
8 | Locked | 40.3 | 23 | 0 |
9 | Locked | 40.3 | 19 | 0 |
10 | Locked | 40.3 | 7 | 0 |
11 | Locked | 40.3 | 1 | 0 |
12 | Locked | 40.3 | 13 | 0 |
13 | Locked | 40.3 | 8 | 0 |
14 | Locked | 40.3 | 6 | 0 |
15 | Locked | 40.3 | 10 | 0 |
16 | Locked | 40.3 | 10 | 0 |
17 | Locked | 40.3 | 7 | 0 |
18 | Locked | 40.9 | 8 | 0 |
19 | Locked | 40.3 | 16 | 0 |
20 | Locked | 38.9 | 13 | 0 |
21 | Locked | 38.9 | 7 | 0 |
22 | Locked | 40.3 | 10 | 0 |
23 | Locked | 40.3 | 21 | 0 |
24 | Locked | 40.3 | 18 | 0 |
on 05-08-2021 18:26
1 | 46200000 | 43.8 | 5120 | 32 qam | 3 |
2 | 32600000 | 43.8 | 5120 | 32 qam | 5 |
3 | 39400000 | 43.8 | 5120 | 32 qam | 4 |
4 | 53700000 | 43.8 | 5120 | 64 qam | 2 |
5 | 60300000 | 43.8 | 5120 | 32 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 3 | 0 |
4 | ATDMA | 0 | 0 | 63 | 0 |
5 | ATDMA | 0 | 0 | 44 | 0 |
on 05-08-2021 18:27
05/08/2021 17:47:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/08/2021 17:42:14 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 19:22:47 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 18:27:27 | notice | Received REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 18:23:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:57:7 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:57:7 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:56:36 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:56:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:51:10 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:33:29 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:27:16 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:27:16 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:22:56 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:17:36 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:17:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:17:35 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:17:35 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/08/2021 17:01:36 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05-08-2021 22:13 - edited 05-08-2021 22:14
Your upstream Modulation is not all at 64 qam and some T3 timeouts.
Check your cables are well connected to the hub and wall.
Is the cable VM installed and not your own?
on 06-08-2021 08:56
Thanks for the reply.
The cable is VM installed. I’ve just everything is plugged in. Will test it out and see how it goes and report back.
on 06-08-2021 09:05
Still the same issue.
I can trigger it quite easily if I upload something, even as simple as attaching a file to email.
any ideas where to go from here?
thanks again.
on 08-08-2021 11:24
Hello @veeneee,
Welcome to the community page, thank you for posting on here.
I am sorry for your current broadband issues.
I was able to locate your account using your forums details.
I can see you have a engineer appointment, please can you let us know how this goes?
Many thanks,
on 10-08-2021 09:49
The engineer seems to have fixed the fault. All is working normally once more. 👍
on 12-08-2021 12:32
Thank you for the update @veeneee.
Glad to hear this issue has been resolved. Please do not hesitate to contact us if you need any further help :).
