on 08-11-2023 11:28
Can't get through to a human being to talk to on virgin media customer support number. Need to replace my virgin hub 4 with hub 5, always connection drops via WiFi, theb hub itself gets extremely hot
on 08-11-2023 15:58
See this....
Firstly... Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
After that we can suggest things to try to sort any issues on the Hub4
