Exposed cables on external wall
LouB13
The box covering my connections on the external wall has come off. This has left the cables and connections exposed to the elements. Can someone from the Forum Team let me me know
I arrange for an engineer to come and check there is no damage and to replace the covering so everything is safe and secure? At the moment my services are working but this is clearly dangerous and I want to avoid any major damage by getting it sorted. I have tried calling and it is impossible to speak to someone with all of the menu options.
1 ACCEPTED SOLUTION
Accepted Solutions
Kain_W
Hi LouB13,
Thanks for posting your concern and welcome back to the community.
The box posted on the image looks like to have seen better days, sorry to see that!
So we can arrange to get this sorted I've dropped you a PM to discuss further.
The message will appear within the envelope icon.
Regards,
Kain
1 REPLY 1
Kain_W
Hi LouB13,
Regards,
Kain
