on 13-02-2022 16:47
For the last week the internet keeps dropping out. I work from home and getting grief from my employers, as Im a call centre worker. When we watch UTube or Amazing fire sticks, its often buffers and cuts off. Ive done diagnostics and checked for blackspots, no issues all great according to Virgin connect app. Can anyone help please?? Thanks
on 13-02-2022 16:50
Does it do the same on a wired connection?
on 13-02-2022 23:19
It does it on them all. This evening I worked out its happens when my son is online streaming upstairs at same time. The main TV is a wired connection and it did it on that when stream watching stuff on the Amazon stick.
on 13-02-2022 23:26
Post the Network, Upstream and Downstream logs from the hubs admin pages back here as text
on 14-02-2022 00:03
Ive no idea how to do that?
on 16-02-2022 09:01
Hello @Amanda,
Welcome back, thanks for posting.
I am sorry for the issues with your internet.
Can you please tell me if you was able to resolve this? I checked my system, no outages are in the area. Also no errors on your up/down streams.
Many thanks,
on 16-02-2022 09:26
Hi Hayley,
I called Virgin, they said upload speed is 200ish (Im on their 200 internet) but its not, its only 49ish. They weren't why it was showing differently at their end. They told me to run speed tests whilst talking to them, which confirmed 49ish upload. They said they get engineer to fix it remotely but no change over 24 hours later.
This is what we checked...
on 18-02-2022 10:40
Thanks for the update @Amanda8623.
Can you please tell me what speeds you are getting on your wired connection?
Many thanks,
on 18-02-2022 13:57
Hi. Same, about 40 download and 20 upload - Thanks
on 21-02-2022 08:52
Thank you for coming back to us @Amanda862.
I have this morning run some further diagnostics & have been able to find some power level issues, I am going to pop you over a PM so that I can confirm your address.
Kind regards,
Zak_M
