on 09-09-2022 20:03
How can I stop virgin changing my wifi channel settings
on 09-09-2022 20:31
on 09-09-2022 21:01
Sorry John, I have been running with your suggestion for several years. Until very recently I have had no problem. Now even with optimisation off virgin keeps resetting my 5G channel to ch44 along with 4 other local strong signals. Ch36 has been grabbed by Sky, My BT wifi has been allocated Ch48 (by me) Ch40 is totally clear (nothing over 100dBm). Every time I do as I have done previously and allocate and save Ch40, optimisation off, the "SMART" Hub resets it to Ch44. I tried to prevent Virgin upgrading my hub to "SMART" as I suspected that this would happen but they must have slipped it in somehow.
Thanks for suggestion though.
on 10-09-2022 15:13
on 12-09-2022 15:42
Hey FredBloggs60, thank you for reaching out and to answer your question the WIFI wouldn't work as well if you turned these channels off.
If you wanted to look at changing the settings I can help you.
Please do let me know. Thanks
Matt - Forum Team
New around here?
12-09-2022 15:57 - edited 12-09-2022 15:58
That is so bad. The HUB 3 allowed you to turn off the SmartWiFi setting (which everyone should do as it's a pest).
My cynical mind tells me, prolly accurately, that these settings were giving VM serious support grief so they removed them from the Hub 4 and, I assume Hub 5. Fair to say, I'm working off my screen shots taken in 2020 before I put the Hub4 into Modem Mode.
I recommend anyone with some IT or network nous to use their own router with the hub in modem mode.
on 12-09-2022 16:11
@Sephiroth.
@HUB 5 has this feature, it can be disabled.....BUT it is a requirement to be enabled, when using "Intelligent Pods"
on 12-09-2022 16:20
on 12-09-2022 16:54
Matt, I'm not trying to disable these channels, I know my local Wifi environment and until recently I could allocate my 5G channel to Ch40 and it stayed there. Now when I manually set the channel to Ch40 with auto set to off, Virgin always moves it back to Ch44 within minutes.
Channel 44 has 4 separate Virgin accounts nearby ranging in strength from -70dBm to -50dBm. Ch40 has no signals above -100dBm.
Thanks for advice Matt, but unless you know how to permanently switch of smart I still need to look further into it.
on 12-09-2022 19:38
@FredBloggs60 wrote:How can I stop virgin changing my wifi channel settings
You can't if you want to change channels get your own router
