2 weeks ago
I have been having problems where I need to keep resetting my router.
I have a hub 5 set to modem mode and a negear r7000 router.
Here are the logs from modem
09-06-2024 21:27:18 | notice | GUI Login Status - Login Success from LAN interface |
09-06-2024 21:07:57 | notice | GUI Login Status - Login Success from LAN interface |
09-06-2024 20:57:11 | notice | GUI Login Status - Login Success from LAN interface |
09-06-2024 20:38:18 | notice | GUI Login Status - Login Success from LAN interface |
09-06-2024 19:26:53 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
09-06-2024 19:26:49 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-06-2024 19:26:44 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-06-2024 19:26:41 | notice | TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-06-2024 19:26:38 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-06-2024 19:26:36 | notice | Honoring MDD; IP provisioning mode = IPv4 |
09-06-2024 19:26:27 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-06-2024 19:26:26 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
09-06-2024 17:10:12 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
09-06-2024 17:10:12 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-06-2024 05:44:46 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-06-2024 05:44:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-06-2024 05:44:20 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-06-2024 05:43:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-06-2024 05:43:53 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-06-2024 05:43:53 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
28-05-2024 16:35:23 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 16:35:22 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
27-05-2024 18:12:46 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 18:12:45 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
25-05-2024 08:18:56 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
25-05-2024 08:18:53 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
20-05-2024 16:53:20 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
20-05-2024 16:53:20 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-05-2024 19:46:21 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
18-05-2024 19:46:20 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
17-05-2024 11:53:06 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2024 11:52:18 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2024 11:52:11 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
17-05-2024 11:52:11 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
07-05-2024 15:03:12 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
07-05-2024 15:02:10 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
3.0 Downstream channels
1 | 331000000 | 3.8 | 40 | QAM 256 | 25 |
2 | 139000000 | 6.6 | 39 | QAM 256 | 1 |
3 | 147000000 | 6.5 | 39 | QAM 256 | 2 |
4 | 155000000 | 6.2 | 40 | QAM 256 | 3 |
5 | 163000000 | 5.9 | 39 | QAM 256 | 4 |
6 | 171000000 | 5.6 | 39 | QAM 256 | 5 |
7 | 179000000 | 5.4 | 39 | QAM 256 | 6 |
8 | 187000000 | 5.2 | 39 | QAM 256 | 7 |
9 | 195000000 | 5.1 | 40 | QAM 256 | 8 |
10 | 203000000 | 4.8 | 39 | QAM 256 | 9 |
11 | 211000000 | 4.6 | 40 | QAM 256 | 10 |
12 | 219000000 | 3.8 | 39 | QAM 256 | 11 |
13 | 227000000 | 2.7 | 39 | QAM 256 | 12 |
14 | 235000000 | 1.5 | 39 | QAM 256 | 13 |
15 | 243000000 | 1.9 | 39 | QAM 256 | 14 |
16 | 251000000 | 3.2 | 39 | QAM 256 | 15 |
17 | 259000000 | 3.6 | 39 | QAM 256 | 16 |
18 | 267000000 | 3.7 | 39 | QAM 256 | 17 |
19 | 275000000 | 3.7 | 39 | QAM 256 | 18 |
20 | 283000000 | 3.7 | 39 | QAM 256 | 19 |
21 | 291000000 | 3.8 | 39 | QAM 256 | 20 |
22 | 299000000 | 4 | 40 | QAM 256 | 21 |
23 | 307000000 | 4.2 | 39 | QAM 256 | 22 |
24 | 315000000 | 4.1 | 40 | QAM 256 | 23 |
25 | 323000000 | 4 | 40 | QAM 256 | 24 |
26 | 339000000 | 3.8 | 39 | QAM 256 | 26 |
27 | 347000000 | 3.2 | 39 | QAM 256 | 27 |
28 | 355000000 | 2.3 | 39 | QAM 256 | 28 |
29 | 363000000 | 1.9 | 39 | QAM 256 | 29 |
30 | 371000000 | 1.8 | 39 | QAM 256 | 30 |
31 | 379000000 | 2.1 | 39 | QAM 256 | 31 |
1 | Locked | 40 | 0 | 0 |
2 | Locked | 39 | 0 | 0 |
3 | Locked | 39 | 0 | 0 |
4 | Locked | 40 | 0 | 0 |
5 | Locked | 39 | 0 | 0 |
6 | Locked | 39 | 0 | 0 |
7 | Locked | 39 | 0 | 0 |
8 | Locked | 39 | 0 | 0 |
9 | Locked | 40 | 0 | 0 |
10 | Locked | 39 | 0 | 0 |
11 | Locked | 40 | 0 | 0 |
12 | Locked | 39 | 0 | 0 |
13 | Locked | 39 | 0 | 0 |
14 | Locked | 39 | 0 | 0 |
15 | Locked | 39 | 0 | 0 |
16 | Locked | 39 | 0 | 0 |
17 | Locked | 39 | 0 | 0 |
18 | Locked | 39 | 0 | 0 |
19 | Locked | 39 | 0 | 0 |
20 | Locked | 39 | 0 | 0 |
21 | Locked | 39 | 0 | 0 |
22 | Locked | 40 | 0 | 0 |
23 | Locked | 39 | 0 | 0 |
24 | Locked | 40 | 0 | 0 |
25 | Locked | 40 | 0 | 0 |
26 | Locked | 39 | 0 | 0 |
27 | Locked | 39 | 0 | 0 |
28 | Locked | 39 | 0 | 0 |
29 | Locked | 39 | 0 | 0 |
30 | Locked | 39 | 0 | 0 |
31 | Locked | 39 | 0 | 0 |
3.1 Downstream channels
41 | 94 | 4K | 1840 | QAM 4096 | 1108 |
41 | Locked | 37 | -5.9 | 163626986 | 3 |
3.0 Upstream channels
0 | 49600000 | 47.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 47.3 | 5120 | QAM 64 | 2 |
2 | 36600000 | 47 | 5120 | QAM 64 | 3 |
3 | 30100000 | 47 | 5120 | QAM 64 | 4 |
4 | 23600000 | 47 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
6 | 10.4 | 43.5 | 2K | QAM 256 |
6 | OFDMA | 208 | 74000000 | 0 | 0 |
2 weeks ago
See this....
If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then, click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
2 weeks ago
a week ago
Hi @mikeelbon
Thanks for posting and welcome back to the community. Apologies for any broadband issues. I can see you've spoke to the team and had an engineer visit since posting.
Hopefully all fixed soon for you.
Best wishes.
