on 08-07-2022 17:38
Hi, this may be a somewhat lengthy post,
I'll have to split hub readings from the other day / after a restart today.
The basics out of the way first:
Superhub 3, modem mode. - wired
I have made sure all connections are finger tight.
I have checked both the online fault checker and the phone one
The following first set of logs I post will be from then (Before rebooting the hub).
The other night, 7th July - I noticed a huge latency spike, this turned out to be a Partial service error.
Obviously along with that comes a flood of post-RS errors, as expected.
I am sorry for the formatting on this particular section:
07/07/2022 00:07:15 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:07:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:07:14 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:06:16 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:06:15 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:05:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:05:14 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/07/2022 00:03:28 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1 Locked 40.3 3057 6731
2 Locked 40.9 1858 7104
3 Locked 40.9 1836 7435
4 Locked 40.9 1828 5666
5 Locked 40.3 1621 5757
6 Locked 40.3 1627 5633
7 Locked 40.3 1811 5775
8 Locked 40.3 1808 5749
9 Locked 40.3 1573 5101
10 Locked 40.3 1876 5284
11 Locked 40.3 1689 5669
12 Locked 40.3 1896 5574
13 Locked 40.3 2822 6718
14 Locked 40.3 1878 6648
15 Locked 40.9 1831 6211
16 Locked 40.3 1893 6552
17 Locked 40.3 2115 6110
18 Locked 38.9 2531 7290
19 Locked 40.3 2399 7146
20 Locked 38.6 3513 7108
21 Locked 38.9 3432 7220
22 Locked 38.9 3493 6851
23 Locked 38.9 3308 6668
24 Locked 38.6 3401 6886
1 ATDMA 0 0 10 0
2 ATDMA 0 0 12 0
3 ATDMA 0 0 6 0
4 ATDMA 0 0 12 0
Even through this, all my upstream QAM were locked to 64,
Until today, that is.
The following posts will show todays logs AFTER a reboot.
on 30-09-2022 19:37
Another update,
Still no fixed power levels,
Now I'm getting packet loss
and a channel has dropped back to 16QAM.
Going to have to split this post into two, due to text limits.
1 | 411000000 | -6.5 | 38 | 256 qam | 1 |
2 | 419000000 | -6.7 | 38 | 256 qam | 2 |
3 | 427000000 | -6.9 | 38 | 256 qam | 3 |
4 | 435000000 | -7.2 | 38 | 256 qam | 4 |
5 | 443000000 | -7.5 | 38 | 256 qam | 5 |
6 | 451000000 | -7.5 | 38 | 256 qam | 6 |
7 | 459000000 | -7.5 | 38 | 256 qam | 7 |
8 | 467000000 | -7.5 | 38 | 256 qam | 8 |
9 | 475000000 | -7.7 | 38 | 256 qam | 9 |
10 | 483000000 | -7.7 | 38 | 256 qam | 10 |
11 | 491000000 | -7.9 | 38 | 256 qam | 11 |
12 | 499000000 | -8.2 | 38 | 256 qam | 12 |
13 | 507000000 | -8.2 | 38 | 256 qam | 13 |
14 | 515000000 | -8.4 | 38 | 256 qam | 14 |
15 | 523000000 | -8.5 | 37 | 256 qam | 15 |
16 | 531000000 | -8.7 | 37 | 256 qam | 16 |
17 | 539000000 | -9 | 37 | 256 qam | 17 |
18 | 547000000 | -9.2 | 37 | 256 qam | 18 |
19 | 555000000 | -9.4 | 37 | 256 qam | 19 |
20 | 563000000 | -9.5 | 37 | 256 qam | 20 |
21 | 571000000 | -9.9 | 37 | 256 qam | 21 |
22 | 579000000 | -10 | 37 | 256 qam | 22 |
23 | 587000000 | -10 | 37 | 256 qam | 23 |
24 | 595000000 | -10 | 37 | 256 qam | 24 |
1 | Locked | 38.9 | 155 | 0 |
2 | Locked | 38.9 | 94 | 0 |
3 | Locked | 38.9 | 170 | 0 |
4 | Locked | 38.9 | 75 | 0 |
5 | Locked | 38.9 | 131 | 0 |
6 | Locked | 38.9 | 113 | 0 |
7 | Locked | 38.6 | 168 | 0 |
8 | Locked | 38.6 | 90 | 0 |
9 | Locked | 38.9 | 103 | 0 |
10 | Locked | 38.6 | 110 | 0 |
11 | Locked | 38.9 | 123 | 0 |
12 | Locked | 38.9 | 134 | 0 |
13 | Locked | 38.6 | 155 | 0 |
14 | Locked | 38.9 | 101 | 0 |
15 | Locked | 37.6 | 222 | 0 |
16 | Locked | 37.6 | 144 | 0 |
17 | Locked | 37.3 | 216 | 0 |
18 | Locked | 37.6 | 275 | 0 |
19 | Locked | 37.6 | 166 | 0 |
20 | Locked | 37.6 | 367 | 0 |
21 | Locked | 37.6 | 775 | 0 |
22 | Locked | 37.6 | 511 | 0 |
23 | Locked | 37.6 | 512 | 0 |
24 | Locked | 37.6 | 469 | 0 |
1 | 49600249 | 49.3 | 5120 | 64 qam | 1 |
2 | 36600025 | 48.5 | 5120 | 64 qam | 3 |
3 | 30100157 | 48 | 5120 | 64 qam | 4 |
4 | 43100239 | 48.8 | 5120 | 64 qam | 2 |
5 | 23599902 | 47.7 | 5120 | 16 qam | 5 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 2 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 30-09-2022 19:39
https://www.thinkbroadband.com/broadband/monitoring/quality/share/99d0211a42b0af7eea816fe43594835dbd...
Link to my live BQM where the packet loss is visible on 30th September, just before and after 7PM.
Hoping this is just a power level/SNR issue and that the whole repull wasn't a waste of time.
on 30-09-2022 21:16
Okay, T3's are climbing on Channel 5
5 | ATDMA | 0 | 0 | 7 | 0 |
SNR issue inc!
on 03-10-2022 08:30
When I had this issue about 18 months ago, it was a problem that was at the head end that no one was monitoring. After multiple engineers, a repull etc it was some dodgy fibre cable. Took 2 months to fix and now I have different issues. Anyone in your area you can do a BQM on?
on 03-10-2022 09:28
Hi Icantcrabhere,
Thanks for your post, I am sorry you're having this issue with your broadband services recently, thank you for taking the time to post your logs.
I have had a look at your services on my side and can see there is an area outage, which is regarding an SNR issue.
This is due to be fixed - 04 OCT 2022 09:00 - but please be aware this is just an estimate, it could change depending on what the engineers find. However, I am sure they will be working incredibly hard to get this fixed as soon as possible for you.
Megan_L
03-10-2022 16:16 - edited 03-10-2022 16:19
@Comradebro
Luckily this time it seems to be an SNR issue,
however sadly no, I don't have anyone else locally who has a BQM, or who is willing to discuss their levels etc.
I tried before with other locals in a FB group, but I don't think they were comfy with the idea.
and most of our neighbours are with different providers.
Thankfully a new FTTP provider is in town, so there's one positive through all this mess 🙂
and thank you for the update, Megan!
01-11-2022 20:22 - edited 01-11-2022 20:26
Well this is neat.
Logs taken after a fresh restart.
Channels dropping from 64QAM again.
Nothing in the Modem log worth posting, except from previous T3's.
And yes my power levels are completely wrong, just like before and they didn't get anyone out to fix them 🙂
1 | 49600233 | 49.3 | 5120 | 64 qam | 1 |
2 | 43100254 | 49 | 5120 | 64 qam | 2 |
3 | 36600000 | 49.7 | 5120 | 16 qam | 3 |
4 | 30100171 | 48 | 5120 | 32 qam | 4 |
5 | 23599814 | 47.5 | 5120 | 16 qam | 5 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
1 | 411000000 | -6.4 | 38 | 256 qam | 1 |
2 | 419000000 | -6.5 | 38 | 256 qam | 2 |
3 | 427000000 | -6.7 | 38 | 256 qam | 3 |
7 | 459000000 | -7.4 | 38 | 256 qam | 7 |
9 | 475000000 | -7.5 | 38 | 256 qam | 9 |
11 | 491000000 | -7.7 | 38 | 256 qam | 11 |
14 | 515000000 | -8.2 | 38 | 256 qam | 14 |
17 | 539000000 | -8.9 | 37 | 256 qam | 17 |
21 | 571000000 | -9.7 | 37 | 256 qam | 21 |
24 | 595000000 | -9.9 | 37 | 256 qam | 24 |
1 | Locked | 38.9 | 0 | 0 |
2 | Locked | 38.9 | 4 | 0 |
3 | Locked | 38.9 | 5 | 0 |
4 | Locked | 38.9 | 0 | 0 |
5 | Locked | 38.6 | 5 | 0 |
6 | Locked | 38.9 | 5 | 0 |
7 | Locked | 38.6 | 5 | 0 |
8 | Locked | 38.9 | 6 | 0 |
9 | Locked | 38.9 | 5 | 0 |
10 | Locked | 38.6 | 6 | 0 |
11 | Locked | 38.6 | 5 | 0 |
12 | Locked | 38.6 | 0 | 0 |
13 | Locked | 38.6 | 0 | 0 |
14 | Locked | 38.6 | 7 | 0 |
15 | Locked | 37.6 | 5 | 0 |
16 | Locked | 37.3 | 5 | 0 |
17 | Locked | 37.3 | 12 | 0 |
18 | Locked | 37.6 | 0 | 0 |
19 | Locked | 37.6 | 5 | 0 |
20 | Locked | 37.3 | 6 | 0 |
21 | Locked | 37.3 | 5 | 0 |
22 | Locked | 37.3 | 5 | 0 |
23 | Locked | 37.6 | 0 | 0 |
24 | Locked | 37.6 | 5 | 0 |
Also according to the fault checker:
"Looks like there’s an intermittent signal issue in your areaTo make sure it's not the kit in your home that's causing the issue, follow our steps to check your cables. And don’t worry, if you need a technician we can set that up from here."
take that as you will.
Feels like I'm liviing in a cursed area right now:
Countless technicians,
A repull,
loads of SNR issues.
What an absolute headache
on 02-11-2022 10:43
on 02-11-2022 15:52
Hey there, Comeradebo!
Running a Hub3 🙂
If i were to take the attenuators off my power levels would actually be higher, scary right?
In regards to slope, It's actually low powered the closer we get to the cabinet (Or was before the repull, at least).
Unfortunately I wasn't here the day of the repull, so I have no idea which cable they actually replaced it with.
Sadly for the most part it has been generic responses from technicans, etc - i'm assuming it has been the same for you.
It's definitely an odd situation, sorry to hear you're having to deal with it too!
If VM were to compensate me for all these issues? - it still wouldn't cover the price of the paracetamol i've used 🙂
Hopefully we can get our issues resolved, fellow headache brother!
on 02-11-2022 16:34
