jamaykans
Message 1 of 5
Help with connection/speed
Just installed virgin broadband 108Mbps M100 fibre, it works fine in the living room where the router is but in bedrooms a little further there is no connection or super slow.
My question: Will this problem be solved if I upgrade to M200 fibre and 213Mbps?
Or do I solve it with an extender?
Or does it help to switch provider? i currently have virgin media trial.
Help please
We are three people sharing the flat.
DigitalDreams
  • 48
Message 2 of 5
Re: Help with connection/speed
Can the router be positioned closer to all users (more central). You may need an extender connected to one of the ethernet ports otherwise.
  • 35.04K
  • 3.41K
  • 6.66K
Message 3 of 5
No dont upgrade. What Hub model is it ? Sounds like it may just be a poor wifi issue - rather than a connectivity issue.
See this....
______
Do you know if its a wifi only issue (ethernet connections are ok?), if it is - then On a Hub3/4/5, you could first try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings At the same time switch off "channel optimisation/Smart wifi” and “ apply and save the settings. All wifi devices will now need reconnecting to the best SSID at each location. Also use a wifi scanning App to find the best wifi channels to use (just select and use channels 1,6,11 on 2.4GHz) - this often helps Hub users get better wifi performance - so its worth trying - but its still no substitute for getting better kit 🙂
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 20 Mbps/room it’s now called… Wifi Max see.-
https://www.virginmedia.com/wifi-max & https://www.virginmedia.com/broadband/intelligent-wifi
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible it will be £5 or £8 month - you are… and it wont be - just look on the webpage.
If not free to you… you will be charged £8/month (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point (4) A combination of (2,3).
£30-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage.
  • 1.71K
  • 107
  • 391
Super solver
Message 4 of 5
Another reason not to upgrade, at the end of 2022 M100 (108/10) was replaced with M125 which is a now a 132/20 Mb/s service.
Kath_F
  • 34.65K
  • 1.33K
  • 2.8K
Message 5 of 5
Hi jamaykans,
Thanks for your post and a big welcome to the Community. It's great having you on board with us in the forums.
We're sorry to hear that you're having an issue with your WiFi connection.
We'd love to take a look in to things but have been unable to locate you on our systems using your forum credentials. We will need to confirm some information with you in order for us to proceed with checks.
I have sent you a direct message to allow us to do this with you in a private space. Just click on the little envelope at the top right-hand side of the page to access your inbox.
Kath_F
