on 15-01-2023 10:51
Hi, I need to change where the cable enters the house. Black cable from road through wall connected to white box internally. That needs to change to run down the side of the house at ground level then come into an alternative room.
Can I do this myself or does VIrgin need to do it? I rang spoke to advisor who put me on hold and came back saying I can- but upon seeing lots of posts saying the contrary?
on 15-01-2023 11:54
VM will do this for a standard charge of £25. Do not be temped to DIY this work, as VM will have to check signal levels etc, after any cable alterations.
A VM Mod will pick this up in a day or two.
on 17-01-2023 12:23
Hi there RKPSEP,
Thanks for your post and welcome to the community.
So as @Adduxi has advised, we can arrange for this to be completed however there would be £25 call out charge.
I've dropped you a PM so we can get this sorted.
The message will appear within the purple envelope icon.
Regards,
on 19-01-2023 09:55
Thanks for your cooperation over PM RKPSEP,
That appointment is booked in for you now.
Do let us know if you have any other queries.
Also let us know how the appointment goes!
Take care,
