on 09-02-2022 12:28
WIFI keeps dropping in and out. Even when low usage, ie one work laptop. Had issues since set up 29th Dec, had engineer visit who found issues outside (did not specify) called engineer back to report still having issues but never heard back.
When I do get wifi speeds are sloooowwwww
Impossible to speak with human to get another visit organised.
Ive reset the hub numerous times, when the app works ive done home scans which state wifi is available in all rooms (its really not) app rarely works anyways.
how do I speak to a human at VM to help sort this, I keep getting bots.
Answered! Go to Answer
on 10-02-2022 07:46
Ignore that last poster - it’s spam.
on 09-02-2022 12:52
Is this just with WiFi, or are wired connections poor as well?
on 09-02-2022 13:01
seems to just be wifi
on 09-02-2022 13:22
Diagnostics in the settings indicates issues with the wifi, however no idea what this is or how to fix it.
09-02-2022 15:43 - edited 09-02-2022 15:45
Have you followed the WiFi Wins advice?
https://community.virginmedia.com/t5/Digital-life/WiFi-Wins/ba-p/3958523
How far from the Hub are you using the WiFi? You may need to use a separate router or a mesh system.
on 09-02-2022 17:25
Hi yes, done the wifi wins, apparently no black spots in the house when i scan it with the app, when the app actually works of course. Loss of wifi literally sometimes in the same room as router, and just outside the room. This is happening even when there’s only a works laptop drawing traffic.
on 09-02-2022 17:35
It sounds like WiFi contention or radio interference.
Have you installed a WiFi analyser app on your phone and had a look see what channel your WiFi is on and whether there are many contenting WiFi networks from neighbours etc?
Do you know if you are connecting via 2.4GHz or 5GHz? If not, you can separate out the WiFi channels ... (give them separate names) and then explicitly choose which one you connect to. But you can't do that if you are using WiFi Pods. So... do you have any WiFi Pods installed?
on 09-02-2022 17:49
Not yet I’ve been looking at which app would be the best to use.
I tried to switch to using the separate 2.4 & 5GHz channels today but when I select them in the settings it won’t save, it’s taking too long and times out, or says it’s saved setting but the once refreshed has defaulted back. I’ll try again
I don’t have wifi pods.
on 09-02-2022 18:08
I think it is recommended to turn off channel optimisation too.
I've only ever run my hubs in modem mode, so can't add too much there.
What phone/tablet are you looking to install a WiFi Analyser on?
on 09-02-2022 20:24
Ok thanks, I’ll make sure that’s off too.
I beleive I can use the IMac to run a check via the utilities, otherwise it would be an app for iPhone/pad
