on 18-02-2022 15:30
I need an engineer to come to my property however how do I do this as website is very complex
on 18-02-2022 17:04
on 19-02-2022 16:38
Thanks for your reply.
I lost my partner in 2020 and he used to do all of the home networking etc, so you can imagine I am trying to learn a lot. We have a VM Hub3, which is then connected into another router.
I also have TpLink plugs around the home which operate my CCTV and printer, which disconnect due to weak WIFI signal - to reconnect I have to disconnect the mains power and give it a reboot.
I need a VM engineer to see if the Hub is in the best location in the house.
on 19-02-2022 17:50
As per your other post you can get the hub moved, but it will possibly not improve the WiFi. We can recommend various solutions, but before then we must check out your incoming signal to see if that is a problem. Go into the hub and supply some stats, details below:
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
on 19-02-2022 19:55
on 22-02-2022 10:00
Hi Goliw02,
Thanks for your post and a big welcome to the Community. It's great having you on board with us.
I'm sorry to hear about the issues you have been having with your broadband. I'm happy to take a look in to things but I've been unable to locate you on our systems using your forum credentials. I will need to confirm some information with you in order for me to proceed with checks.
I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
on 23-02-2022 15:53
Hi Goliw02,
Thanks for coming back to me on this one via private message.
Taking a look at our systems, I can see there is an open fault affecting your connection. The details are below:
I have made a note of this on your account so the relevant teams are aware you are affected. If there is anything else we can do, let us know.
on 23-02-2022 15:57
Thanks Kath - good to understand that there is a fault.
My hub3 is showing a red light at the bottom is this ok or does is the faulty?
Finally I understand that the phone line is changing over to fibre and I need to connect phone in the back of the hub but they are in two different locations - is there away that I can book out an engineer?
Thank you for your help
Wendy Golightly
on 23-02-2022 16:52
Thanks for your reply. VM have confirmed there is an open fault at my address and should be fixed on 1st March 22.
