on 12-09-2022 18:45
Acquired Downstream Channel (Hz) | 355000000 | Locked |
Ranged Upstream Channel (Hz) | 46199969 | Locked |
Provisioning State | Online |
1 | 355000000 | 3.4 | 38 | 256 qam | 28 |
2 | 203000000 | 1.7 | 38 | 256 qam | 9 |
3 | 211000000 | 1.7 | 38 | 256 qam | 10 |
4 | 219000000 | 1.7 | 38 | 256 qam | 11 |
5 | 227000000 | 1.7 | 38 | 256 qam | 12 |
6 | 235000000 | 1.7 | 38 | 256 qam | 13 |
7 | 243000000 | 1.7 | 38 | 256 qam | 14 |
8 | 251000000 | 2 | 38 | 256 qam | 15 |
9 | 259000000 | 2.2 | 38 | 256 qam | 16 |
10 | 267000000 | 2.4 | 38 | 256 qam | 17 |
11 | 275000000 | 2.4 | 38 | 256 qam | 18 |
12 | 283000000 | 2.7 | 38 | 256 qam | 19 |
13 | 291000000 | 2.9 | 38 | 256 qam | 20 |
14 | 299000000 | 3.2 | 38 | 256 qam | 21 |
15 | 307000000 | 3 | 38 | 256 qam | 22 |
16 | 315000000 | 3 | 38 | 256 qam | 23 |
17 | 323000000 | 3.5 | 38 | 256 qam | 24 |
18 | 331000000 | 3.4 | 38 | 256 qam | 25 |
19 | 339000000 | 3.2 | 38 | 256 qam | 26 |
20 | 347000000 | 3 | 38 | 256 qam | 27 |
21 | 363000000 | 3.4 | 38 | 256 qam | 29 |
22 | 371000000 | 3.5 | 38 | 256 qam | 30 |
23 | 379000000 | 3 | 38 | 256 qam | 31 |
24 | 387000000 | 2.5 | 38 | 256 qam | 32 |
1 | Locked | 38.6 | 7 | 0 |
2 | Locked | 38.9 | 6 | 0 |
3 | Locked | 38.6 | 8 | 0 |
4 | Locked | 38.6 | 5 | 0 |
5 | Locked | 38.6 | 5 | 0 |
6 | Locked | 38.6 | 9 | 0 |
7 | Locked | 38.6 | 6 | 0 |
8 | Locked | 38.6 | 7 | 0 |
9 | Locked | 38.6 | 4 | 0 |
10 | Locked | 38.9 | 6 | 0 |
11 | Locked | 38.6 | 5 | 0 |
12 | Locked | 38.6 | 7 | 0 |
13 | Locked | 38.9 | 6 | 0 |
14 | Locked | 38.6 | 7 | 0 |
15 | Locked | 38.9 | 6 | 0 |
16 | Locked | 38.6 | 9 | 0 |
17 | Locked | 38.6 | 8 | 0 |
18 | Locked | 38.9 | 5 | 0 |
19 | Locked | 38.6 | 6 | 0 |
20 | Locked | 38.6 | 5 | 0 |
21 | Locked | 38.9 | 7 | 0 |
22 | Locked | 38.6 | 10 | 0 |
23 | Locked | 38.6 | 5 | 0 |
24 | Locked | 38.9 | 20 | 0 |
1 | 46199969 | 48.8 | 5120 | 64 qam | 1 |
2 | 23599988 | 48.8 | 5120 | 64 qam | 4 |
3 | 32600034 | 48.8 | 5120 | 64 qam | 3 |
4 | 39400021 | 48.8 | 5120 | 64 qam | 2 |
on 12-09-2022 18:53
Figures all in range.
on 12-09-2022 19:23
i restarted my router as i was lagging.
now my levels are this
Acquired Downstream Channel (Hz) | 187000000 | Locked |
Ranged Upstream Channel (Hz) | 46199993 | Locked |
1 | 187000000 | 2.2 | 38 | 256 qam | 7 |
2 | 139000000 | 3 | 38 | 256 qam | 1 |
3 | 147000000 | 2.7 | 38 | 256 qam | 2 |
4 | 155000000 | 2.7 | 38 | 256 qam | 3 |
5 | 163000000 | 2.7 | 38 | 256 qam | 4 |
6 | 171000000 | 2.7 | 38 | 256 qam | 5 |
7 | 179000000 | 2.5 | 38 | 256 qam | 6 |
8 | 195000000 | 2 | 38 | 256 qam | 8 |
9 | 203000000 | 1.9 | 38 | 256 qam | 9 |
10 | 211000000 | 1.9 | 38 | 256 qam | 10 |
11 | 219000000 | 1.9 | 38 | 256 qam | 11 |
12 | 227000000 | 1.9 | 38 | 256 qam | 12 |
13 | 235000000 | 1.9 | 38 | 256 qam | 13 |
14 | 243000000 | 1.7 | 38 | 256 qam | 14 |
15 | 251000000 | 2.2 | 38 | 256 qam | 15 |
16 | 259000000 | 2.4 | 38 | 256 qam | 16 |
17 | 267000000 | 2.5 | 38 | 256 qam | 17 |
18 | 275000000 | 2.5 | 38 | 256 qam | 18 |
19 | 283000000 | 2.7 | 38 | 256 qam | 19 |
20 | 291000000 | 3 | 38 | 256 qam | 20 |
21 | 299000000 | 3.4 | 38 | 256 qam | 21 |
22 | 307000000 | 3.2 | 38 | 256 qam | 22 |
23 | 315000000 | 3.2 | 38 | 256 qam | 23 |
24 | 323000000 | 3.7 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 0 | 0 |
2 | Locked | 38.6 | 5 | 0 |
4 | Locked | 38.6 | 6 | 0 |
5 | Locked | 38.6 | 4 | 0 |
6 | Locked | 38.6 | 0 | 0 |
7 | Locked | 38.9 | 5 | 0 |
8 | Locked | 38.6 | 4 | 0 |
10 | Locked | 38.6 | 5 | 0 |
12 | Locked | 38.6 | 5 | 0 |
13 | Locked | 38.9 | 5 | 0 |
14 | Locked | 38.9 | 0 | 0 |
15 | Locked | 38.9 | 5 | 0 |
16 | Locked | 38.6 | 0 | 0 |
17 | Locked | 38.9 | 6 | 0 |
18 | Locked | 38.6 | 0 | 0 |
19 | Locked | 38.9 | 0 | 0 |
20 | Locked | 38.9 | 5 | 0 |
21 | Locked | 38.9 | 6 | 0 |
22 | Locked | 38.6 | 4 | 0 |
23 | Locked | 38.6 | 0 | 0 |
24 | Locked | 38.6 | 5 | 0 |
1 | 46199993 | 48.8 | 5120 | 64 qam | 1 |
2 | 23599979 | 48.8 | 5120 | 64 qam | 4 |
3 | 32600019 | 48.8 | 5120 | 64 qam | 3 |
4 | 39400036 | 48.8 | 5120 | 64 qam | 2 |
is this still normal? why the change
12-09-2022 19:33 - edited 12-09-2022 19:33
Docsis levels can be fine but how it works can cause problems if the area by others is sending stuff on the upstream.
on 12-09-2022 20:15
