on 17-01-2021 13:09
I'm sure this has been done to death, but I am struggling with out connection at the moment.
I am at the point of resetting daily to try to make sure we can last the day with an ok connection.
We have also got lacking connection around the house, black spots where we previously had none.
Any advice much appreciated, I am thinking of investing in a mesh system to try to help but not sure if it would solve the daily drop of internet.
on 17-01-2021 13:15
Which Hub do you have ?
What is your contracted speed ?
What speeds do you get at >> SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
on 17-01-2021 13:20
I have a hub 3 M200 package. Just after reset generally get 150 wireless connection. Sometimes better. It then drops to 0.5 download or No internet connection. But is fine again after a reset.
The black spots have been like it for several months now where previously we had great connection all around the house.
on 17-01-2021 13:54
on 17-01-2021 14:10
@Leeroywarner wrote:I have a hub 3 M200 package. Just after reset generally get 150 wireless connection. Sometimes better. It then drops to 0.5 download or No internet connection. But is fine again after a reset.
What are your wired speeds and connectivity like?
17-01-2021 14:55 - edited 17-01-2021 14:59
on 17-01-2021 15:00
on 17-01-2021 15:03
I'm pretty sure it just stays the white lower light although occasionally we get green flashing but I think that has been when there is other issues in the area.
on 17-01-2021 15:12
17-01-2021 15:19 - edited 17-01-2021 15:19
I got a WiFi extender to help get signal to my study, and that helps for one of the black spots. I am happy to spend the money on either a mesh or better router if either would potentially fix the issue. But unsure of which would be better?
What is the virgin media option at £5 per month?
