on 04-11-2021 21:44
Hi. My broadband which vice only had for a month keeps dropping out. I have rebooted my hub. I have a hub4 not a hub3. I have done a factory reset -i still cannot even logon to the 192.168.0.1 with the factory password. I can see the router status logs which show it keeps dropping off. Even in the middle of the night when my google home which is set as a clock and I wake up to it saying no internet connection. It's so intermittent and seems to be getting worse. I don't understand why I cannot even log on to the admin page of the hub. I'm using the correct password. Once my tv box stopped working too. So wonder if there a faulty wire somewhere in the outside of my house?? Any advice?
Answered! Go to Answer
on 05-11-2021 14:46
You do not have to logon to the hub to get full set of stats, only if you want to make changes and you do not.
How to get stats from a VM hub
on 04-11-2021 23:00
@Annamarieheath wrote:I have done a factory reset -i still cannot even logon to the 192.168.0.1 with the factory password. I can see the router status logs which show it keeps dropping off.
You say you can't log into admin page of the hub4, yet you can see the router status logs?
If you are using a 3rd party router as well as the hub then you need to log into 192.168.100.1 and NOT 192.168.0.1
Also make sure you are using the Settings password and not the wifi password, both of which are printed on the base of the hub.
on 05-11-2021 06:18
Thanks Dave, I see where you're coming from, however, I'm not using anything other than the hub 4 that is directly connected the the Virgin Media inlet toly house. Definitely using the admin password and not wifi password.i can see the status logs because the login screen asked for username and password (tells me in getting it wrong) -but right at the bottom of the logon screen says view status (you don't have to logon) am totally baffled.
on 05-11-2021 14:46
on 05-11-2021 19:06
Thank you, hope this makes some sense to you?
networking
Tue Oct 12 00:34:47 2021 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:34:50 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:34:56 2021 | 6 | CM-STATUS message sent. Event Type Code: 4; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:35:35 2021 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:35:40 2021 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:35:43 2021 | 3 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:38:33 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:39:11 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:39:40 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:43:54 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 12 00:44:47 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Oct 13 02:13:47 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Oct 13 19:11:11 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Oct 13 22:40:05 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 14 12:55:54 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 14 12:56:20 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Oct 15 11:56:08 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Oct 16 04:37:28 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Oct 16 07:22:42 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 17 12:51:39 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 17 15:00:53 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Oct 18 09:48:27 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Oct 18 11:23:55 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Oct 20 22:31:25 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 21 05:57:02 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Oct 22 15:16:12 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 24 10:31:25 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Oct 25 02:24:34 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 26 12:49:23 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Oct 26 18:13:15 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Oct 27 22:31:25 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 28 03:09:38 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 28 23:15:43 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Oct 28 23:34:57 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Oct 29 04:45:50 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 31 01:48:19 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 31 09:31:25 2021 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Oct 31 09:43:09 2021 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov 2 21:26:12 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov 2 21:26:38 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov 3 18:13:48 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov 3 18:13:54 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov 3 18:18:24 2021 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov 3 18:18:50 2021 | 5 | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 05-11-2021 19:07
upstream
1 | 46200000 | 46.750000 | 5120 KSym/sec | 64QAM | 1 |
2 | 32600000 | 46.750000 | 5120 KSym/sec | 64QAM | 3 |
3 | 25800000 | 46.500000 | 5120 KSym/sec | 64QAM | 4 |
4 | 39400000 | 46.750000 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
4 | US_TYPE_STDMA | 0 |
on 05-11-2021 19:09
20 | 291000000 | 3.900002 | 40.366287 | QAM256 | 20 |
1 | 139000000 | 6.800003 | 40.366287 | QAM256 | 1 |
2 | 147000000 | 6.000000 | 40.366287 | QAM256 | 2 |
3 | 155000000 | 5.400002 | 40.366287 | QAM256 | 3 |
4 | 163000000 | 5.300003 | 40.366287 | QAM256 | 4 |
5 | 171000000 | 5.199997 | 40.366287 | QAM256 | 5 |
6 | 179000000 | 5.000000 | 40.366287 | QAM256 | 6 |
7 | 187000000 | 5.000000 | 40.946209 | QAM256 | 7 |
8 | 195000000 | 4.800003 | 40.946209 | QAM256 | 8 |
9 | 203000000 | 4.500000 | 40.946209 | QAM256 | 9 |
10 | 211000000 | 4.300003 | 40.366287 | QAM256 | 10 |
11 | 219000000 | 4.199997 | 40.946209 | QAM256 | 11 |
12 | 227000000 | 4.000000 | 40.366287 | QAM256 | 12 |
13 | 235000000 | 3.599998 | 40.366287 | QAM256 | 13 |
14 | 243000000 | 3.200001 | 40.366287 | QAM256 | 14 |
15 | 251000000 | 3.099998 | 40.366287 | QAM256 | 15 |
16 | 259000000 | 3.400002 | 40.946209 | QAM256 | 16 |
17 | 267000000 | 3.799999 | 40.366287 | QAM256 | 17 |
18 | 275000000 | 4.400002 | 40.946209 | QAM256 | 18 |
19 | 283000000 | 4.199997 | 40.366287 | QAM256 | 19 |
21 | 299000000 | 3.299999 | 40.366287 | QAM256 | 21 |
22 | 307000000 | 3.200001 | 40.366287 | QAM256 | 22 |
23 | 315000000 | 3.299999 | 40.946209 | QAM256 | 23 |
24 | 323000000 | 3.700001 | 40.366287 | QAM256 | 24 |
25 | 331000000 | 3.599998 | 40.366287 | QAM256 | 25 |
26 | 371000000 | 3.299999 | 40.366287 | QAM256 | 26 |
27 | 379000000 | 3.200001 | 40.946209 | QAM256 | 27 |
28 | 387000000 | 3.200001 | 40.366287 | QAM256 | 28 |
29 | 395000000 | 3.000000 | 40.366287 | QAM256 | 29 |
30 | 403000000 | 2.700001 | 40.366287 | QAM256 | 30 |
31 | 411000000 | 2.200001 | 40.366287 | QAM256 | 31 |
32 | 419000000 | 1.900002 | 40.366287 | QAM256 | 32 |
20 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.946209 | 0 | 0 |
9 | Locked | 40.946209 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.946209 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.366287 | 0 | 0 |
16 | Locked | 40.946209 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.946209 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.946209 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
25 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.946209 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
32 | Locked | 40.366287 | 0 | 0 |
on 08-11-2021 09:33
Hi Annamarieheath, Thank you for your post 🙂
I am sorry to hear you are having issues, I have checked your power levels and all looks fine. Are you able to set up a BQM graph to monitor your dropouts? You can do so here
on 08-11-2021 18:08
thanks for your reply Zoie. I will look at how to set up a BQM graph. In the meantime, can you offer any assistance with the fact I cannot log in to my hub, despite doing a pin reset and using the factory password (which I’ve never changed?)
on 08-11-2021 18:34
The default password is case sensitive.
Meaning if the letters printed on the bottom of the hub are capital or lowercase you must type them capital or lowercase.
