on 02-12-2021 01:26
I've seen a few topics like this but none had any solutions.
From Sept 29th my superhub was rebooting (or otherwise losing connection and re-establishing it) between 1am and 2am. When the clocks went back, this window changed to somewhere between midnight and 1am. So either the superhub can't tell time, or something outside of the hub can't tell time if it happens within the same time frame every day.
Most of the time the internet's off for 5-10 minutes while it reboots. Sometimes it doesn't manage to reconnect until 4-6am. Rebooting the superhub does nothing.
I phoned the customer support today, the guy on the other end hadn't heard of this problem before. I don't blame him, it sounds outside of the normal issues one would have. My area apparently has a connection consistency issue which prevented him calling a technician out since there's already a logged problem. On his advice I restored the hub to factory default (holding down the reset button for 15 seconds) and spent an hour rebuilding my wireless network from scratch rather than importing a backup. At about 12:40, the internet went down again.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9561050659e21885a13326857f1eb27315617d9d-29-11-2021
Here's a graph from the 29th November so as not to confuse with the two reboots I did on the 1st Dec trying to fix the issue.
1 | 139000000 | 0.7 | 38 | 256 qam | 1 |
2 | 147000000 | 1 | 38 | 256 qam | 2 |
3 | 155000000 | 1.5 | 38 | 256 qam | 3 |
4 | 163000000 | 2 | 38 | 256 qam | 4 |
5 | 171000000 | 2.4 | 38 | 256 qam | 5 |
6 | 179000000 | 2.7 | 38 | 256 qam | 6 |
7 | 187000000 | 2.7 | 38 | 256 qam | 7 |
8 | 195000000 | 2.5 | 38 | 256 qam | 8 |
9 | 203000000 | 2.5 | 38 | 256 qam | 9 |
10 | 211000000 | 2.4 | 38 | 256 qam | 10 |
11 | 219000000 | 2.2 | 38 | 256 qam | 11 |
12 | 227000000 | 2 | 38 | 256 qam | 12 |
13 | 235000000 | 2 | 38 | 256 qam | 13 |
14 | 243000000 | 2 | 38 | 256 qam | 14 |
15 | 251000000 | 2.5 | 38 | 256 qam | 15 |
16 | 259000000 | 3.2 | 38 | 256 qam | 16 |
17 | 267000000 | 3.7 | 38 | 256 qam | 17 |
18 | 275000000 | 4.1 | 38 | 256 qam | 18 |
19 | 283000000 | 4.8 | 38 | 256 qam | 19 |
20 | 291000000 | 5 | 38 | 256 qam | 20 |
21 | 299000000 | 5.5 | 38 | 256 qam | 21 |
22 | 307000000 | 6 | 40 | 256 qam | 22 |
23 | 315000000 | 6.3 | 40 | 256 qam | 23 |
24 | 323000000 | 6.3 | 40 | 256 qam | 24 |
1 | Locked | 38.6 | 12 | 0 |
2 | Locked | 38.6 | 7 | 0 |
3 | Locked | 38.6 | 6 | 0 |
4 | Locked | 38.9 | 5 | 0 |
5 | Locked | 38.9 | 6 | 0 |
6 | Locked | 38.9 | 11 | 0 |
7 | Locked | 38.9 | 5 | 0 |
8 | Locked | 38.9 | 5 | 0 |
9 | Locked | 38.6 | 19 | 0 |
10 | Locked | 38.6 | 9 | 0 |
11 | Locked | 38.6 | 7 | 0 |
12 | Locked | 38.9 | 5 | 0 |
13 | Locked | 38.6 | 6 | 0 |
14 | Locked | 38.9 | 0 | 0 |
15 | Locked | 38.9 | 4 | 0 |
16 | Locked | 38.6 | 0 | 0 |
17 | Locked | 38.9 | 6 | 0 |
18 | Locked | 38.6 | 5 | 0 |
19 | Locked | 38.9 | 5 | 0 |
20 | Locked | 38.9 | 3 | 0 |
21 | Locked | 38.9 | 5 | 0 |
22 | Locked | 40.3 | 5 | 0 |
23 | Locked | 40.3 | 17 | 0 |
24 | Locked | 40.3 | 5 | 0 |
on 02-12-2021 01:26
1 | 60300000 | 51 | 5120 | 64 qam | 1 |
2 | 53700000 | 51 | 5120 | 64 qam | 2 |
3 | 46199980 | 51 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
02/12/2021 00:52:34 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/12/2021 00:46:13 | Warning! | TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/12/2021 00:46:13 | Warning! | Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/12/2021 00:29:38 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/12/2021 00:13:14 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 23:29:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 22:54:52 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 22:43:13 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 22:42:27 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 22:40:14 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 17:21:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 17:18:11 | Warning! | TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 17:18:11 | Warning! | Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 17:16:3 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 17:15:35 | critical | REG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 17:15:35 | Error | T6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 17:15:35 | critical | Registration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 17:15:35 | critical | Registration RSP rejected message syntax error;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 16:52:21 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/12/2021 16:48:5 | Warning! | TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 02-12-2021 07:42
on 02-12-2021 17:31
Would that cause the hub to reboot on a night? Or is that just a general issue? What can an incorrect upstream do?
on 02-12-2021 22:36
Looking at your log, the hub has not rebooted, it’s just lost its connection to the VM CMTS. This is almost certainly due to the lack of 4 upstream channels and the very high power level on the existing ones. Do this:
Check with Area faults on 0800 561 0061 or if you have a VM landline 150
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait a day or two for a VM staff member to get to your post.
on 03-12-2021 01:19
As stated in my initial post, the guy I spoke to was unable to send an engineer out since there's a consistency issue logged in the local area. He couldn't go through any trouble shooting options because of that.
Area faults on the 0800 number said everything was fine.
Could the upstream really cause a disconnect at the same time frame every day? Like, within the same hour?
on 03-12-2021 02:09
on 03-12-2021 15:00
Turned it off for 5 minutes and the upstream looks like this.
2 | 46200000 | 51 | 5120 | 64 qam | 3 |
3 | 53700000 | 51 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 0 | 0 |
So no real change.
Though I think you're being a bit unfair to the tech support guy. He knew it needed a technician, but couldn't get one for me because there's an existing problem in the area.
It's not a great look calling them droids reading from a script if you don't actually read the things I'm posting, because I said as much at least once, possibly twice.
I'll carry on waiting to see if a VM support person comes along. I appreciate the help thus far, it's nice to know what the potential cause might be. Still find it odd that this doesn't just cause random losses rather than losses in a specific time frame.
on 03-12-2021 15:11
on 03-12-2021 15:41
Thanks for your posts @Dragon_Nexus,
I've been able to run a flow on your equipment and can see we will need an engineer.
Check out the purple envelope in the top right hand corner for a private message from me
Kindest regards,
David_Bn
