on 05-05-2023 09:41
Hi ...I wanted to use my Hub3 DOCSIS 3.0 Router on a home network. On researching the subject i have found that it is possible to use a router with a usb port to facilitate this. However sadly my router does not have a usb port on it. My question is.......if i got an ethernet to usb adaptor would this work?. If so would there be any configuration settings to alter?
Answered! Go to Answer
05-05-2023 10:35 - edited 05-05-2023 10:53
What exactly are you trying to do? What are you trying to set up?
Is this for a share on your home network - USB drive in rear of hub/router so you can share files/media with different devices, or even externally?
Forget trying to do this with a Hub 3 (or any other VM hub).
Some ISP hubs/routers, including some of the BT Home Hubs, will allow this but not all. Better to use a third party router that offers this capability.
Ethernet to USB? Not really. Such devices are normally used to connect a device/computer that lacks an Ethernet interface, but has USB functionality. It's not going to let you do what you want to do - You would still need a DLNA server, SAMBA (for Windows FS) and so on. They need to run on a 'box' of some sort with processing power.
My D Link router allows all that plus FTP server, if required - sharing content on a USB drive plugged into the back of the router.
Better still get a NAS drive....
on 05-05-2023 10:20
Your description is a bit vague. What actually are you trying connect to the VM Hub? Is it a PC or a Hard Disk?
on 13-05-2023 07:36
thanks for the input.....thought as much...NAS it is then cheers
on 13-05-2023 07:37
thanks for the input ...now sorted .....gone for NAS setup
