09-05-2023 21:43 - edited 09-05-2023 22:04
I wonder if anyone could share some light with me regarding my hub issue, We have been experiencing internet issue for months now - I have reboots and reset many time and some time the internet work kind of okay after reset but having to do this all the time in order to get the internet to work is quite ridiculous
The router is always on orange light, and I have ignored it since I thought it might be an LED issue. However, when I reset or reboot the router, the other light colour appears to be working normally.
Currently, the internet is getting worse, the wi-fi range wouldn't reach within 10-15 steps from the router and the ethernet sometimes just didn't work (this is the reason why I was constantly resetting and rebooting). The hub is always hot, I don't know if it overheated, and the orange light keeps showing up even after rebooting/resetting.
I've spoken with three different agents today and all of their recommendations are for me to pay for more speed. Have asked for a hub replacement, they said it would not solve my issue, and they kept saying that the only way to make it better is to upgrade my speed. My hub speed is M350
this make me consider switching provider
Thank you
on 09-05-2023 21:49
This is an image of my hub
on 09-05-2023 21:54
That looks the same colour mine was, I don't think the led age is related to your issue
on 09-05-2023 22:29
Had my Hub 3.0 for about the month and it's exactly the same, totally useless. Tried every fix possible.
Just put my old 2.0 hub back in and it's fine.
on 10-05-2023 21:29
unfortunately, this is our only hub 😥
on 10-05-2023 21:30
did your issue get resolve?
on 13-05-2023 09:59
Hi there @7yrswithVM
I am so sorry that you have faced this issue with your service and thank you for updating us.
Is the Hub warm to the touch at all? Also have you tried a full factory reset? To do this push a pen etc into the reset hole and hold in for 60 seconds.
If you have changed any Hub setting they will revert to the original settings, but you can change these back again.
