on 09-07-2022 07:51
I posted a problem with the hub 3 displaying constant red light, i did reply to the followup question with the following info
Sorry i should have put this info in the original post
yes the hub is in space and not boxed in
When i did the factory reset the hub felt hot to touch..
But since then no one has got back to me....
Can someone please advise...
on 09-07-2022 09:36
No need to start a new thread......
It sounds like you may need a new hub - wait for a forum rep to get back to you or contact VM.
on 09-07-2022 12:55
Hey opusnine, thank you for reaching out and I am sorry to see you have a red light on your hub.
I am going to send you a PM, so we can get this looked into.
Please look out for the purple envelope.
In the meanwhile can you please try these steps;
• Then use the power switch to turn the unit back on. The Hub should now operate normally. Thanks
Matt - Forum Team
New around here?
on 09-07-2022 12:56
@Matthew_ML wrote:Hey opusnine, thank you for reaching out and I am sorry to see you have a red light on your hub.
The OP already covered all that in his other thread about this.
on 16-07-2022 15:30
It got sorted...
The engineer swapped it for a new hub
Thanks.
on 18-07-2022 18:18
Hey opusnine, thank you so much for your update on this.
We are glad to see our engineer has been able to restore your issue by replacing your router.
Please, feel free to post again in our forum page should you face any issues in the future, we're always happy to help.
We do hope you will not need us though - have a great day 🙂
