on 26-10-2022 10:54
We upgraded to Volt Gig1 recently and replaced Hub 3 with Hub 4. We now have noticeable packet loss at certain times of day.
I've been using Think Broadband's Broadband Quality Monitor to keep track. Here's a link to the live graph.
This is an example of a bad day on 24th October 2022. The red at the top of the chart is packet loss with the axes on the right hand side. More red = higher packet loss:
Nearly 20% lost packets for a period in the morning and a smaller loss in the afternoon.
This was one the week before on 18th October:
Similar problems in the morning and afternoon.
Please could someone check my connection and let me know if there is anything I can do to resolve this? Thanks
on 27-10-2022 16:24
We appear to be having packet loss problems again this afternoon. I've copied the Router Status below in case anyone can shed any light on my problems.
3 | 427000000 | 1.400002 | 38.983261 | QAM256 | 3 |
1 | 411000000 | 1.400002 | 40.366287 | QAM256 | 1 |
2 | 419000000 | 1.299999 | 40.366287 | QAM256 | 2 |
4 | 435000000 | 1.599998 | 40.366287 | QAM256 | 4 |
5 | 443000000 | 1.900002 | 40.366287 | QAM256 | 5 |
6 | 451000000 | 2.000000 | 40.946209 | QAM256 | 6 |
7 | 459000000 | 1.700001 | 40.946209 | QAM256 | 7 |
8 | 467000000 | 1.599998 | 40.366287 | QAM256 | 8 |
9 | 475000000 | 1.400002 | 38.983261 | QAM256 | 9 |
10 | 483000000 | 1.700001 | 40.946209 | QAM256 | 10 |
11 | 491000000 | 1.700001 | 40.366287 | QAM256 | 11 |
12 | 499000000 | 1.599998 | 38.983261 | QAM256 | 12 |
13 | 507000000 | 1.299999 | 40.366287 | QAM256 | 13 |
14 | 515000000 | 1.400002 | 38.983261 | QAM256 | 14 |
15 | 523000000 | 1.299999 | 38.983261 | QAM256 | 15 |
16 | 531000000 | 1.400002 | 40.366287 | QAM256 | 16 |
17 | 539000000 | 1.400002 | 40.366287 | QAM256 | 17 |
18 | 547000000 | 1.299999 | 40.366287 | QAM256 | 18 |
19 | 555000000 | 1.200001 | 40.366287 | QAM256 | 19 |
20 | 563000000 | 1.000000 | 38.983261 | QAM256 | 20 |
21 | 571000000 | 1.200001 | 38.983261 | QAM256 | 21 |
22 | 579000000 | 1.000000 | 38.983261 | QAM256 | 22 |
23 | 587000000 | 0.900002 | 38.983261 | QAM256 | 23 |
24 | 595000000 | 0.599998 | 38.983261 | QAM256 | 24 |
25 | 603000000 | 0.900002 | 38.983261 | QAM256 | 25 |
26 | 611000000 | 1.099998 | 38.605377 | QAM256 | 26 |
27 | 619000000 | 0.900002 | 38.605377 | QAM256 | 27 |
28 | 627000000 | 0.400002 | 38.605377 | QAM256 | 28 |
29 | 635000000 | 0.400002 | 38.983261 | QAM256 | 29 |
30 | 643000000 | 0.299999 | 38.983261 | QAM256 | 30 |
31 | 651000000 | 0.099998 | 38.605377 | QAM256 | 31 |
3 | Locked | 38.983261 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 19 | 0 |
5 | Locked | 40.366287 | 2 | 0 |
6 | Locked | 40.946209 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 40.946209 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
25 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.605377 | 0 | 0 |
27 | Locked | 38.605377 | 0 | 0 |
28 | Locked | 38.605377 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.605377 | 0 | 0 |
159 | 96 | 4K | 1880 | QAM4096 | 759 |
159 | Locked | 39 | -3.9 | 991971223 | 0 |
1 | 49600000 | 43.520599 | 5120 KSym/sec | 64QAM | 1 |
2 | 23600000 | 42.020599 | 5120 KSym/sec | 64QAM | 5 |
3 | 30100000 | 42.520599 | 5120 KSym/sec | 64QAM | 4 |
4 | 36600000 | 42.520599 | 5120 KSym/sec | 64QAM | 3 |
5 | 43100000 | 43.020599 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 3 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
6 | 10.0 | 38.8 | 2K | QAM8 |
6 | OFDMA | 200 | 53.9 | 0 | 0 |
on 30-10-2022 10:10
Hi @Onyx1811,
Thanks for your post, and welcome to the Community Forums.
I'm sorry to hear you're facing problems with Packet Loss on your service. I've taken a look on our side and everything is within specification and there is no indication of a fault. I can, however, see that your Hub has been online for more than 14 days. Can you please try to reboot the Hub, by switching it off at the back, waiting for 30 seconds before switching it back on?
This will refresh any connections to the network. It will also allow us to run more accurate diagnostics.
Cheers,
on 30-10-2022 14:14
Thank you @Recce_MH, I've restarted the Hub 4.
on 01-11-2022 14:47
Thanks for the update,
How is the service for you now Onyx1811?
Let us know,
02-11-2022 10:10 - edited 02-11-2022 10:11
Hi @Kain_W,
I am still having intermittent problems. Yesterday afternoon/evening is an example:
I'm trying to understand if this is something that is being caused from within my own network or if it is something on the Virgin side of things. During these periods of packet loss it's pretty much impossible to have a video call.
Is there anything you or anyone else can suggest I can do to help diagnose this?
Thanks!
on 03-11-2022 11:55
on 04-11-2022 08:05
I've run mtr to test connectivity to one of the DNS servers when I'm having problems and I think it shows that packets are being lost between my hub on IP 192.168.0.1 and the next hop at 10.53.39.145. I know that all 10.x addresses are "private", so is this something internal to the virgin network?
This is after running mtr -n 194.168.4.100 on ubuntu connected to the hub directly via cable:.
My traceroute [v0.95]
block-01 (192.168.0.86) -> 194.168.4.100 (194.168.4.100) 2022-11-04T07:31:12+0000
Packets Pings
Host Loss% Snt Last Avg Best Wrst StDev
1. 192.168.0.1 0.0% 28 16.3 23.8 1.1 227.3 42.9
2. 10.53.39.145 15.4% 27 21.0 14.4 10.1 21.0 2.8
3. 62.253.98.1 11.5% 27 25.6 19.7 11.1 40.1 7.3
4. 194.168.4.100 11.5% 27 15.4 10.9 6.9 15.4 2.8
This is consistent with my observations during other periods of packet loss. I've run tracepath and based on the latency I think that 10.53.39.145 is definitely outside my house. If this is the case I think that implies that the problem is with the comms between my hub and the cabinet?
$ tracepath 194.168.4.100
1?: [LOCALHOST] pmtu 1500
1: _gateway 1.345ms
1: _gateway 1.877ms
2: 10.53.39.145 16.429ms
3: winn-core-2a-xe-2018-0.network.virginmedia.net 11.675ms
4: cache1.service.virginmedia.net 15.226ms !H
Resume: pmtu 1500
Any help gratefully received!
on 06-11-2022 12:46
Hi Onyx1811,
Thank you for reaching out to us in our community and welcome, sorry to hear you are facing packet loss on our 1GB connection, I was able to locate you on our system with the details we have for you and cannot see any issues at all, how have things been your end since your last post?
Paul.
06-11-2022 13:27 - edited 06-11-2022 13:31
@Paul_DN wrote:Hi Onyx1811,
Wow so even with hub in router mode doing all the tests that you say you can't do in modem mode and still you can't find an issues? yet BQM shows a issue to the hub! guess the tests need to be made better or just stop using them if they can't help find the issue
But on another note checking your BQM @Onyx1811 today shows no packet loss
