on 09-08-2021 18:47
Since yesterday the wifis been pretty terrible. I was playing Apex legends completely fine and then the wifi dropped and everyone connected lost wifi for a while. I reset the hub and also switched it off, when i switch it back on the wifi doesn’t come back on for at least 30 minutes to an hour. I get green flashing lights and occasionally a red one. Not sure what happened with it but i hope someone can help solve this issue. Thank you in advance
on 09-08-2021 18:53
on 09-08-2021 19:25
im unable to call in, thats why im here. Ive checked for area issues but it says that everythings all good
on 09-08-2021 19:33
on 10-08-2021 18:41
It happens on everything, i think its Hub 3?. Only the white arrow light comes on. When i reset it, the wifi symbol and the arrows flash green and then occasionally the arrows will flash red
on 10-08-2021 18:44
on 13-08-2021 10:10
Good morning Jodie_20
I'm really sorry to hear of the broadband issues. I've had a check on our system and your area is affected by an SNR outage (signal to noise ratio).
Says the following; You might find that your Virgin Fibre, Virgin TV or TiVo® services are intermittent, with the picture freezing or disappearing now and then. We are sorry and our engineers are working hard to resolve this for you.
The fault reference for your records is F009218307 and the estimated fix date is the 19th of August at 15.20.
Best,
on 13-08-2021 19:13
Thank you! All is appreciated
on 16-08-2021 09:17
You're more than welcome
Do monitor the connection after this date and let us know if you need further assistance
Best,
