on 13-03-2022 21:31
We have just installed the new HUB 5 but my windows laptop won’t connected to the Wi-Fi.
I have followed everything but when I click to find our Wi-Fi it’s not there. I can see everyone else’s nearby.
Help!
on 26-08-2022 09:37
on 28-08-2022 11:06
Hi @aosullivan thanks a lot for your reply.
Apologies, we do of course mean your desktop PC.
Does the desktop connect to the broadband when connected via ethernet cable, can you try this to see if this then picks up the wifi shortly after the disconnection of the cable?
I'd also recommend following @mjpartyboy's tips in terms of checking the wireless adapter's advanced settings, having a look at this to see if there's anything that could be preventing your desktop from seeing our wifi.
I hope this helps and please let us know if you need any further help.
Many thanks
on 28-08-2022 20:10
I cannot try an Ethernet cable as the router is in a different room
i have checked the Wi-Fi card as best I can, but not knowing what all the advanced setting do.. I am not doing to risk changing anything without specific advice
on 31-08-2022 09:51
Hi aosullican1977,
Thank you for your reply.
With the advanced network settings for your desktop, we would recommend speaking with your manufacturer directly for more detailed instructions.
There also may be an online forum who can also offer support with this.
Ideally, we would need to test the Hub via a wired connection to establish if this is a WiFi or hardware issue. Do any other devices have difficulty connecting since splitting the connections?
on 08-09-2022 08:59
on 10-09-2022 09:52
Hi mjpartyboy, thanks for posting and welcome back to our community.
Sorry to hear that your laptop is not connecting to WiFi. When you say your home network, do you mean our hub, or do you mean a 3rd party router? It is our router, have you tried a pinhole reset of your hub? If you do attempt this, please ensure you have access to the default password, before doing so?
Lee_R
on 04-11-2022 21:08
Hi All - so I think I have found the solution. If you dont want to change network details on virgin, then change your network band of windows from 2.4 Hz to 5 Hz.
Use the below link and go to option:
Once done this will work
