on 28-03-2022 14:49
Hi - our Hub 5 seems to only allow certain devices on its main network channel even though the password is correct. I set up a guest network which my daughters and wife are using successfully but i'd like to know why the hub is behaving this way. Any thoughts?
Matt
on 28-03-2022 15:02
on 30-03-2022 15:59
Hi @MWABrown,
Welcome back to our Community Forums and thanks for your post.
I am sorry to hear you're having some issues with certain devices connecting to the hub's main network channel and you've had to set up a guest network as a result.
Can I ask which specific model of device, this issue is with?
on 30-03-2022 19:55
Hi - it’s a Hub 5
Hardware Version 1.1
Software version LG-RDK_2.23.16-2106.14
thanks
M
on 02-04-2022 09:24
Thank you for getting back to us MWABrown, sorry to hear you have been having these issues with the Hub5.
Would you be able to try doing a pinhole reset on the hub and see if the problem persists? (You will need to hold a pin into the 'reset' button on the back of the hub for 60 seconds)
Please do be aware that this will return the hub to its factory settings, and any personalised settings will be lost.
Let us know if there are any other issues you have been having with your Hub 5 so we can raise these internally.
All the best.
