on 15-09-2021 11:06
My Hub 3 loses its 2.5GHz channel. It operates fine on the 5GHz channel, but to access the 2.5GHz channel it keeps asking for the password. When the password is input correctly, it comes back with "Incorrect password" message. I reset the Hub and it worked okay for an hour or so, but then started to ask for password again. The problem is, I need the 2.5GHz channel for my home CCTV cameras. It has worked okay for a few months since I got it. Any ideas, or do I just report to Virgin and get a new Hub?
on 15-09-2021 11:09
on 15-09-2021 11:09
Try a full 60 second factory reset on the Hub.
Remove any ethernet cables from the Hub. Hold the pin hole reset for 60 seconds and DO NOT reboot the Hub afterwards, just let it do it's thing. Make sure the passwords on the bottom of the Hub are legible as you will need these after a factory reset.
on 15-09-2021 11:31
Hi. Thanks. I did a factory reset and it worked for a while, then the 2.5GHz channel fault returned.
on 15-09-2021 11:34
on 15-09-2021 11:36
Thanks. If I go down a separate router, can you suggest one that works with the Hub 3? TP-Link?
on 15-09-2021 11:44
on 15-09-2021 11:46
on 15-09-2021 15:56
Well after spending over 30 minutes on the phone to support, I'm no further forward. "Switch this off, reset, still not working, but I see a couple of devices connected to the 2.4GHz channel." Yes, they work, but I don't know why, but 3 iPhones, 3 laptops, etc. can't connect to the 2.4GHz channel, therefore it's not working. "Okay, try a 60 second reset, okay so it's still not working.?" No it's not. "Okay, I need to speak to tech department, I'll call you back later." No call back so far. As it was left, I didn't have access on certain devices to either channel and so I've reset (10 secs.) and renamed the 5GHz channel, which works. I'll try again tomorrow, but of course since I don't have fault reference number, I'll probably have to start again.
As a business decision, it seems to me it'd be cheaper for Virgin to send me a new Hub 3.
on 17-09-2021 16:01
Hi there @duncanda59
Thank you so much for your post and I am so sorry to see that this has been happening!
Can I ask how things are looking since your last post?
Thanks again.
