on 16-05-2023 19:40
Can anyone help please
Can I use my hub 3 as modem for the mesh system?
on 16-05-2023 19:59
BT Mesh, is that the round disk-like devices?
If so then, no, you can't put the hub into modem mode as the disks don't have any routing/NAT capability, but if you leave the hub in the normal 'router' mode, then certainly you can use the BT disks. Ideally you should disable the hub's WiFi to avoid congestion, but it has a nasty habit of simply re-enabling itself; so don't sweat it!
