on 12-04-2018 10:45
Hub 3.0 settings password (which is printed on the bottom of the router) isn't working. Does Virgin reset this with a different default password and if so how do I get it?
on 05-12-2019 22:24
I'm sorry but i don't think going on a private message is going to help either of us, For you to tell me everything i've tried over the last last day and a half and most probably a bit more as well not to be funny. I've looked at all the forum posts and all the YT videos.
Many Thanks,
Andrew
on 06-12-2019 08:20
Hi there @Sideways316
In order for us to assist you further and arrange a new hub if one is indeed needed then we'll need to chat with you privately so we can go through security with you 🙂
I can see that my colleague has sent you a Private Message to go through this with you so please check for a Purple Envelope and pop them a reply as soon as you can.
Cheers
Katie - Forum Team
on 10-12-2019 17:01
I’m having the same problem, pin-hole reset does not work and i have only had the router since Friday 6th December, new installation.
on 10-12-2019 17:18
Hi there @maelstrom
Welcome to our Community forum and thanks so much for your first post - so sorry to understand that you are having issues with your Hub3.
Have you ever been able to connect to the Hub3 using the information on the bottom of the hub?
When performing a PIN hole reset, we advise to follow these instructions:
1. Find the Ethernet ports on the back of the Hub 3.0
2. Below the Ethernet points, you will see a pinhole marked 'RESET'. Use a paper clip or pen to press the pinhole reset button for 20 seconds
3. The Hub 3.0 should now revert to its factory default settings – the same as those listed on the label on the bottom of the device
4. We recommend that you now turn off the power to the Hub 3.0 for 60 seconds and then turn it back on
Please do try the PIN reset for us and reboot the equipment for us and let us know how you get on 🙂
Cheers
Katie - Forum Team
on 11-12-2019 07:31
tried again last night several times with no joy.....it wont accept the stated password and i am unable to make changes to the router settings, what is the way forward, also this is a brand new hub 3.0 received 6th December!
on 11-12-2019 08:31
Thanks Maelstrom,
Can you confirm you can connect to the internet but not log in to change the settings?
If so then can you make sure you're not using the WiFi password to do this, there is another password on the box which should be eight numbers long.
Can you let me know how you get on?
on 01-01-2020 11:16
I'm having the same issue. Default settings password for Hub 3.0 not working on http://192.168.0.1/
01-01-2020 13:25 - edited 01-01-2020 13:26
OK everyone.... do another factory reset - BUT do it this way....
With the Hub "on" push in the pin on the back/side/bottom of the Hub with the end of a paperclip until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT (repeat do NOT) restart the Hub after that.
Just leave it alone for 5' or so to stabilise and then check that your passwords/passphrase for both the Hub settings and the Wifi networks are the two printed on the Hub sticker on its base/side/card. Make sure you use the settings password to access the Hub and NOT the wifi one.
If that doesn’t sort it - call it in as faulty and insist on a replacement
on 01-01-2020 15:15
@jbrennand wrote:OK everyone.... do another factory reset - BUT do it this way....
This actually worked for me. Thank you.
on 02-01-2020 08:58
not working for me
ive been on the phone takling to the broadband department and they said leave it for 15 mins and it should sort it self out
15 mins later and i still cant log into my settings, saying password is incorrect
