on 22-03-2023 10:59
For the past few months, FaceTime group calls have not been working when we are at home. This affects all of our devices (iPhone 11, iPhone 12 Mini, iPad Air, MacBook Air).
We are able to accept one-to-one FaceTime video and audio calls. When using these devices in other locations, which use different internet providers, we have no problems with group FaceTime calls. The same goes for making the calls on 4G.
We have tried all of the troubleshooting options online, but the details above should clearly point to the fact that our home internet is the problem. When we receive or make a group FaceTime call, we just get stuck with a "Connecting..." message, and the call never connects.
Could this be due to Virgin Media blocking whatever protocol Apple uses for its group FaceTime calls, whether it's set externally or on our hub or something?
Thanks.
on 22-03-2023 11:06
Check the Virgin Media online account settings for Web Safe.
Settings required :
++ Virus Safe - Enabled
++ Child Safe - DIsabled ( if Enable this will block VPN and Conf calls )
on 22-03-2023 19:01
Both of those settings are disabled, so it doesn't seem like that is what causes the issue.
on 25-03-2023 10:06
Hi BBVM,
👋 welcome back to our community! Thank you for for your post, it has been quite a while, hope you have kept well, sorry to hear FaceTime group calls don't work on WiFi, I was able to locate you on our system with the details we have for you cannot see any issues, I was able to find some further information 👉here.
Please let us know how you get on.
Paul.
on 25-03-2023 18:25
Thanks for having a look. We have gone through the steps on that link several times, to no avail. As I said, FaceTime works on those devices on cellular, or in other locations, but not on our home network, for all devices, across two Apple IDs. Even a new device, bought after we first encountered the issue, has the same problem.
I had a look at our router settings the other day and could not see anything out of place, but maybe there is something there. Microsoft Teams and Zoom work with no problems, as do one-to-one FaceTime calls. I suppose that I will just have to hunt around in the settings again then.
on 25-03-2023 18:35
Take a look at Apple's Private Browsing Tools, these are a type of VPN which can affect connectivity. Try with it Disabled and Enabled.
on 26-03-2023 10:54
Private Relay (if that is what you are talking about) requires a paid iCloud account, which neither of us has, so we have it disabled anyway.
on 28-03-2023 11:08
Hi BBVM 👋
Thanks for the updates you've provided on this. Similar to Paul, I've taken a look on our side and there are some levels out of specification on your service. To clarify, have you ever made any changes to your home network through your Hub Settings? If so, can you try reverting these settings to identify which change may be the cause?
Can you also try rebooting your Hub by switching it off at the back, and then switching it back on again?
I've also attempted a group FaceTime call on a Virgin Media home network, and this has worked perfectly fine and all members were able to join - meaning this is most likely an isolated issue on your personal network.
on 28-03-2023 16:05
on 29-03-2023 12:36
Thanks, I will have a look at the settings, but I didn't notice anything that it could be last time I checked, a few days ago. I have tried rebooting my hub a few times before and that never resolved the issue. Group FaceTime worked before, so I know it's not Virgin Media as a whole, just my home network. I'll hunt through the settings again.
