on 20-04-2022 10:05
I have four devices connected via Ethernet. The connections to them definitely work as from time to time (rather randomly) they are connected, but generally only 1 ethernet port works. This is a mystery to me and really irritating as I would prefer to use ethernet for streaming etc.
on 20-04-2022 16:00
on 20-04-2022 16:17
Thanks for responding.
1. Each connected via their own cable
2. Not in modem mode!
groggery1
on 20-04-2022 16:44
on 20-04-2022 17:39
They are all Cat6 cables and are definitely working: they have all had a signal. Have swapped the ports around to see if the issue is the order of connection, but it seems the one going to one of the TVs upstairs always gets a signal if there are multiple cables plugged in. It just seems to like its MAC address and not the others.
on 20-04-2022 19:49
These is a slim possibility that you have an IP clash. I would suggest that you give each device a hardwired IP address in the device, try at string at 192.168.0.250, 251 etc.
on 20-04-2022 19:54
