on 22-02-2022 08:55
After problems with an unstable and weak wifi connection, we made the decision to connect our devices via Ethernet where possible.
Things were fine for a good few months until VM carried out 'improvement works' locally.
Ever since then, any devices connected by ethernet would not connect to the internet. I have checked all connections and devices and they are all good. has anyone else had this problem and found a fix or knows the cause please?
on 22-02-2022 10:25
Try a 60 second factory pinhole reset as below;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
Once done power cycle the cable connected devices. This should fix the issue hopefully.
on 23-02-2022 08:55
I guess this will mean re-setting ALL network passwords for any device connected to my local network?
Regs
on 23-02-2022 10:35
You don’t have to change any device passwords, just go into the hub after the reset and put back any amendments you made.
