on 07-03-2022 15:04
Good afternoon all,
This is my first ever post so please forgive me if I do it all wrong.
I have just installed an "Intelligent WiFi pod" to boost the signal from my 3.0 hub. The signal strength is much improved but my Brennan B2 doesn't seem able to connect to WiFi any more. When I try to connect it goes through some of the routine and then posts "Failed" on the display. The signal strength is fine; if I put my phone next to the machine, it shows a full strength signal but the B2 can't see it.
This means that not only can I not control the B2 from either my phone or an I-pad, I don't have the clock and I can't update its database.
Has anyone else experienced this problem and overcome it?
Any answers gratefully received.
on 07-03-2022 16:04
on 07-03-2022 18:42
Try to disable the 5Ghz wifi band on the Hub as a temporary measure. Then try to connect the B2. If this works, then re-enable the 5Ghz band. It may be the B2 is confused by the single SSID the Pods need to work.
on 08-03-2022 10:59
Thanks for this. The B2 used to work when i had a booster so I don't think that the hub itself is a problem. I am a complete non-tachie but I can't see any options on the hub to change or disable the bands. I think that the signal is a lot weaker than it was, posssibly due to the booster having given up the ghost. I tried taking the pod out of the socket and having the B2 reattach to the WiFi but I still get the same result. It looks like I shall just have to go back to usng the front panel.
on 08-03-2022 14:50
on 08-03-2022 15:19
As a non-techie I really appreciate clear, unambiguous instructions that even I can follow. My son is a techie at the local university and sometimes I think that he can only speak binary and hex.
I'll let you know the results in due course.
