on 14-11-2023 19:56
Since having to change from plugging my gigaset a220 3 phone cordless home phones in to my virgin media hub, the 2 phones that are not plugged in have stopped working. What phone system will work by plugging only one directly in to the hub?
Thank you
on 14-11-2023 21:53
No reason your Gigaset cordless system should not work. The remote handsets may not be communicating with the base. You can check the remote handsets are still linked to the base by 'paging' them. From the phone manual ...
Locating a handset ("Paging")You can locate your handset using the base.
Briefly press the registration/paging key on the base (¢ page 1).All handsets will ring at the same time (“paging”), even if the ringers are switched off.
Ending paging: Briefly press the registration/paging key on the base (¢ page 1) or press the talk key b or the end call key a on the handset
If the remote handsets do not ring, you will need to re-register them to the base station.
