on 08-08-2018 11:21
Since I updated to iOS 11.4.1 my iPhone X attempts to use dial assist for mobile numbers which start 07. The calls then fail with unknown number. Any number in my contacts that's stored with +44 works fine. If I switch dial assist off then the 07 numbers work.
I did the firmware update while in Ireland so I'm wondering if the phone thinks it's in Ireland. I've checked and the region is set to UK.
Does anyone have any ideas?
Answered! Go to Answer
on 16-07-2020 19:24
Bit late to the game here...I’ve been trying to solve this problem on my own for months now 🤯
When I create a new contact, the country ALWAYS defaults to Belgium in the address field. I have not found a way to override this and I wondered if this was at the root of the phone number issue.
Anyone? Bueller? Bueller? Bueller?
on 16-07-2020 19:30
Hi SpankyLeonard
You will find the best solution to the problem in post number 62 by R101.
Good luck ... Derek
on 16-07-2020 22:26
Brilliant! Thanks Derek and R101 xx
on 22-07-2020 15:55
I’ve done all those things too and it still keeps happening. It’s completely infuriating. I’ve also reset to factory settings and that hasn’t helped either.
on 22-07-2020 18:34
Hi Ruth,
This is the solution provided to me and I haven’t had any issues since. Good luck!
Best wishes,
SL
on 24-07-2020 12:40
Hello Martin, I’m constantly having this Belgium number corruption problem and I have tried all of those suggestions with no good results.
it'll fix it for a day, or less, and I have to constantly hard reset or restart my iPhone XR but the problem keeps coming back.
I've even installed iOS 14 public beta 3 to see it the problem was an iOS 13 problem only but, no, it’s still happening.
im left with the choice of leaving Virgin mobile and/or getting a new phone, and not an iPhone now if this isn’t resolved soon by virgins and Apple.
on 24-07-2020 12:57
This should be a permanent fix. As this is a long thread I will post it again
Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming" -> tap "Select Mode"
I found "automatic" was selected by default.
Tap manual -> then choose National.
Now make sure your numbers are set to the correct format. If not change region to anything other than UK (Settings -> General -> Language and Region -> Region) and then change back to UK region
on 24-07-2020 13:02
on 24-07-2020 13:08
Maybe things have changed I know it has worked in the past.
I'm not an iPhone user so no way to check
on 24-07-2020 13:48
Ruth,
I can confirm that I did this when the fix came up (was it a year or 2 ago?) and had no problems since.
I suggest you check as above:
That you have (Settings -> General -> Language and Region -> Region) United Kingdom
I have checked my settings are that.
Also you may have missed the point that perversely, you may have to change it to another region and then change it back again to UK.
