on 26-04-2023 00:48
Hi there, a few days ago wifi calling will turn on but stopped working, with message 'error 0'.
It is an LG Velvet, and I am trying to text/call domestic, within Canada.
Other maybe relevant info - the plan I have did not have wifi calling on it initially; it was added by virgin for me when I upgraded plans, as I live in an area with no mobile connection and is necessary.
Help please, and thanks!
on 26-04-2023 03:52
AFAIK it only worked don Samsung devices but that may have changed, the search function will get the threads.
on 26-04-2023 08:31
Hi @Joelg
Welcome to our community forums and thank you for your first posts.
Sorry to hear you have been having issues with WiFi calling. We want to do our best to help. When did the issue first occur? Have you tried the following link to see if it helps? https://www.virginmedia.com/help/mobile/wifi-and-4g-calling Also what device are you using?
on 26-04-2023 16:16
Actually it worked fine for a year on my LG, til about 10 days ago
on 26-04-2023 16:25
Hi there, my device is an LG Velvet.
Wifi Calling stopped working on the 7th. I turned it off on the 6th when I went into mobile network range, and turned it back on the 7th when I left it. Since then it turns on fine and stays on but does not work
Sorry the link did not help resolve the problem, but thank you
on 26-04-2023 17:26
Hi Joelg 👋
Thanks for providing those details. Just for clarification, you've mentioned texting/calling domestic numbers in Canada. Is this WiFi Calling on a Virgin Mobile Canada/Virgin Plus service?
What happens when attempting to make a call? Are you able to try your SIM in a different device?
on 26-04-2023 19:00
Hi Reece, yes to being on a Virgin Mobile Canada plan.
With text it says. 'can't send message with virgin - error 0', with calling it says 'no mobile network'
Thanks for the response
on 26-04-2023 20:31
Thanks for getting back to us @Joelg
So reading your last response, are you confirming you're a Virgin Mobile Canada customer? As we're based in the UK.
Lee_R
on 27-04-2023 01:31
Haha ok thanks, wrong forum!
