on 30-06-2022 13:59
Hello,
Just returned from Tenerife where I was unable to receive or make calls while there, all set up with roaming and call barring.
I could text and use Apps but no calls in or out?
I see a few others are having same issue, can you add me to the list? thanks
on 30-06-2022 18:07
Hi KennyMo,
A warm welcome and thanks for posting on our community forums. We're sorry to hear that you were unable to receive or make calls whilst abroad on your mobile phone.
You advised that you set up call barring before you went away, did you accidently set this up to bar incoming and outgoing calls whilst abroad?
As you were able to send texts and use Apps, this may be the case.
How did you set your roaming features up? Did you call our Mobile team or do this online?
Kind regards Jodi.
on 30-06-2022 20:39
Online, I'll have another go in September when I'm due abroad again.
on 01-07-2022 08:06
Thanks for your reply @KennyMo, is you are going to check this online when you go abroad again you can do so here. We would advise even if the roaming service is active that it is reset just as a precaution at least 24 hours before you leave the UK.
If you do have any further questions regarding anything to do with roaming we have a really useful roaming page here.
Should you have any further issues while roaming you can also go through some diagnostics on our phone fix page here.
If you need any further support please let us know, we are always happy to help.
Nathan
