on 04-04-2022 15:15
Had a missed call from you and can't ring back. I'm a new customer so I presume it's to do with the set-up/security?
Is there a number I can use?
on 04-04-2022 19:36
29th March. Thank you
on 04-04-2022 20:58
Do you have an account with us and if so, would you be able to pass some account security so I can locate the account and check to see if there are any notes left from an agent trying to make contact.
on 04-04-2022 21:21
I'm not sure if I have an account yet as my order is still processing/awaiting stock. I can log into the mobile part of the virgin media website, if that's any help for you?
on 05-04-2022 08:27
Hi maryamroohipour
If you don't mind, I will need to send you a private message to pass security so I can look into this
If you can check the purple envelope top right of your screen that would be great
Gareth_L
