on 15-07-2022 15:20
Unable to pickup voicemails as a PIN is required. Can my PIN be reset via the app, I can’t see anywhere logical but not to say it isn’t there though!!
on 15-07-2022 15:50
Thanks for your post on our Community Forums @asmetoma, and I'm sorry to hear that accessing your voicemails in Croatia is proving to be tricky.
Check out the purple envelope in the top right hand corner for a private message from me.
Kindest regards,
David_Bn
on 23-07-2022 09:25
Sorted it myself. Called VM directly and had my pin reset. Wasn’t able to initially as not recognised as the main account holder through DMs. Through telephone contact no issues as was able to satisfy all security protocols.
on 23-07-2022 09:29
Thank you for keeping the thread updated with your resolution.
Cheers,
Ryan.
