on 18-10-2021 10:49
Hi all
Looking to put up another virgin tv box (tv 360?) up into a loft conversion that is being started soon.
Wondering if i put something like this behind the tv i could connect the virgin box into this ok? Just need a coax and network connection?
thanks
on 19-10-2021 19:28
VM techs will not connect anything that is non-cable standard. The coax & connectors must not allow Freeview or DAB radio signals to leak into VMs system or all kinds of issues can result on the local network. Most of the ones you buy in the shops will not do this & some are even designed to do the opposite.
