on 15-10-2021 20:23
The Fan on my Hub 4 router is very noisy so much I can here it kicking in and out over the tv volume. Has anyone experienced this also. And is there a fix as it’s very annoying. I intend to speak to VM tomorrow morning. Just wondering if anyone has had the same issue. Thanks in advance
Answered! Go to Answer
17-10-2021 18:49 - edited 17-10-2021 18:51
Have you removed all the cellophane that comes on a new Hub? Otherwise, this would block all the air holes in the Hub and cause overheating
on 17-10-2021 17:51
Hi doesn’t anyone else suffer with the noise of the fan spinning on and off on the Hub 4. Mine sounds like a hairdryer as in kicks in and out during the cooling period. Thanks in advance for any help.
on 17-10-2021 19:47
Thanks for your reply. Yes I gave taken all the plastic off the hub. It sitting on a laminated wooden floor. But we can still here the fan whirling away. It’s very distracting.
on 17-10-2021 20:17
The wooden floor is possibly acting as an echo box to amplify the sound. Try standing the hub on a piece of cork or other sound absorbing material.
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Please read the FAQs
on 17-10-2021 21:33
Great idea thanks for that Graham. I’ll give it a go. 👍
on 18-10-2021 17:05
on 18-10-2021 18:17
Thanks for sharing your advice that’s brilliant idea. I will get some rubber feet. Do you know where you can buy them? I thought Amazon? Any advice will be grateful received. Thank you 😊
on 19-10-2021 01:45
