on 20-03-2024 19:14
I have signed up to VM Broadband and opted for the Steam box. I'm now reading conflicting reports as to whether you can use it, or not, if the Hub is in modem mode, with the Stream box connected via wi-fi through a third party router. I note the FAQ section in this sub-forum says it will work, but then other pages say it wont. Confused!?
Answered! Go to Answer
on 20-03-2024 19:27
Hi @gilbo2
It will work provided you don't use a VPN or different DNS to VM's.
on 20-03-2024 19:27
Hi @gilbo2
20-03-2024 19:38 - edited 20-03-2024 19:40
Just to add to the above more advanced third party routers allow you to assign DNS by device, so you can use other, faster, DNS for all other devices, and the stream can be set to VM's DNS:
Example from my Asus router where I'm using Google DNS for one device, and all other devices use the default set in the router (1.1.1.1 (Cloudfare)):
on 20-03-2024 19:43
@newapollo wrote:Hi @gilbo2
Thank you, that makes sense so will need to check my DNS settings. I usually set them to "assigned by ISP", so hopefully that will sort things out.
on 20-03-2024 19:46
@carl_pearce wrote:Just to add to the above more advanced third party routers allow you to assign DNS by device, so you can use other, faster, DNS for all other devices, and the stream can be set to VM's DNS:
Thanks for that info, my current router isn't as capable as that but is useful to know.
23-03-2024 10:17 - edited 23-03-2024 10:19
You can use different DNS from VMs DNS servers. Originally VM didn't like DNS over TLS and it wouldn't work but this seems to be accepted of late as mine been OK without putting in an exclusion on my router for the Stream box.
On my Asus router I normally do DNS over TLS to cloudflare DNS servers with DNSSec enabled and it all works.
