on 24-02-2022 06:14
Hi, we have recently had the virgin engineer out to check out signal , he said we were getting too much signal which is the same as not getting enough. He turned it down slightly and all was fine for a few hours. Since the. Our 350mb wifi has returned to its normal self , whereby even when we are using our mobile phones for browsing we need to turn the wifi settings off on our phones and go to 4g …… what could this be ? We hit this internet as thought it would be much better than sky
on 25-02-2022 16:00
on 25-02-2022 17:04
The external box looks loose , I may need to book in an engineer
on 28-02-2022 14:58
Hi Neza316,
Thanks for coming back to us to let us know how the engineer visit has gone.
Taking a look at our systems to check the WiFi side of things, our checks have detected high levels of WiFi Interference within the your home. This is causing a poor quality WiFi signal and is impacting multiple devices.
The Hub's location could be causing the coverage problem so we do need to check the positioning of it. Can you please ensure the following:
Think of the Hub as a radio, and WiFi as the sound - the further away you are from the radio, or the more obstacles that are in the way (walls, electronic devices etc.), the quieter the radio & the poorer the WiFi.
To ensure your device is connecting to the best band, turn off the WiFi on the device and turn it back on. This will ensure that the device connects to the fastest band available.
Keep us posted on how you get on.
