on 02-04-2022 07:41
Whenever there is a frost outside, usually early mornings, our TV signal drops out almost entirely and we get the error message 'CS2004 Channel Failedc on all channels until the weather warms up through the day and then the signal comes back fine. This has been happening ever since we had our new 360 box installed and the engineer replaced some of the connections on the Omni Box outside. Yesterday, the broadband signal also dropped out furbto the snow and frost. As it only happens when it's very cold out, by the time customer service is open it has usually resolved itself and they therefore can't find an issue from their end. Please could someone help as it's getting very troublesome in the mornings and I need it sorting.
on 03-04-2022 22:59
An engineer visit would be great, but I can't seem to get one booked
on 03-04-2022 23:11
on 04-04-2022 08:17
Hello shelvock86,
Thanks for bringing this to our attention
Sorry you have had to though
I did check the levels from here and it all appears fine , now the frost has gone
But it will return again and its best to fix it asap
I will be able to get an engineer booked in for you to do this
First though I just need to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
on 04-04-2022 10:44
Thanks for passing security shelvock86
I have booked the engineer and sent the time by private message
I will also check back with you tomorrow to see how the visit went
Gareth_L
on 13-04-2022 21:25
So had an engineer out last Friday but the visit wasn't particularly helpful. Obviously as the weather was good on Friday afternoon he couldn't find an issue with the signal, and he said the connections in the cabinet and Omni Box were fine.
He did however acknowledge that the readings I had taken from the router when cold were not good enough (below 35db), and he said he'd contact network(?) To say there was an issue and then get back to me. Not heard anything from him or Virgin yet, hopefully someone will see this and can chase it up for me.
on 18-04-2022 11:00
Hi Matt
Just a quick message to see how things are
Gareth_L
on 18-04-2022 17:02
Hi Gareth
Not sure what you mean? You said you were going to chase it up for me on Friday so I've just been waiting to here from you?
on 20-04-2022 17:29
Ah sorry. The engineer did pass this over to our networks Team
It s just a bit tricky to diagnose now the Frost has gone
Gareth_L
on 20-04-2022 17:57
Right, does this mean it will be logged as no fault then? Clearly I'm going to be faced with even worse signal when winter comes.
Cheers
on 22-04-2022 18:15
We can run an investigation when the frosts come back again shelvock86
Gareth_L
