on 19-01-2022 13:31
I have a Hub 4 (had it for over a year on the M200 package).
Recently I upgraded to the Gig1 package and have been paying attention to settings etc.
I have no apparent connection issues BUT I did wonder whether I should have left the 15db Forward Path Attenuator in place (currently it is in place on the Hub 4) that was there when I switched from Superhub 2ac to Hub 4 over a year ago)
I believe these are the figures of interest (with the 15db attenuator in place).
Any ideas on whether I should remove it completely or swap it for a differently rated attenuator? If so do VM send these out?
25 | 330750000 | -5.3 | 39 | QAM256 | 25 |
6 | 178750000 | -6.8 | 37.6 | QAM256 | 6 |
7 | 186750000 | -7 | 37.4 | QAM256 | 7 |
8 | 194750000 | -7.3 | 37.6 | QAM256 | 8 |
9 | 202750000 | -7.4 | 37.4 | QAM256 | 9 |
10 | 210750000 | -7.6 | 37.6 | QAM256 | 10 |
11 | 218750000 | -7.7 | 37.6 | QAM256 | 11 |
12 | 226750000 | -8.1 | 37.6 | QAM256 | 12 |
13 | 234750000 | -8.8 | 37.4 | QAM256 | 13 |
14 | 242750000 | -9 | 36.6 | QAM256 | 14 |
15 | 250750000 | -8.1 | 36.6 | QAM256 | 15 |
16 | 258750000 | -7.4 | 37.4 | QAM256 | 16 |
17 | 266750000 | -7.3 | 37.6 | QAM256 | 17 |
18 | 274750000 | -7.2 | 37.6 | QAM256 | 18 |
19 | 282750000 | -7.1 | 37.6 | QAM256 | 19 |
20 | 290750000 | -7 | 37.6 | QAM256 | 20 |
21 | 298750000 | -6.7 | 37.6 | QAM256 | 21 |
22 | 306750000 | -6.1 | 37.6 | QAM256 | 22 |
23 | 314750000 | -5.7 | 37.6 | QAM256 | 23 |
24 | 322750000 | -5.3 | 38.6 | QAM256 | 24 |
26 | 338750000 | -6.1 | 38.6 | QAM256 | 26 |
27 | 346750000 | -6.5 | 38.6 | QAM256 | 27 |
28 | 354750000 | -6.7 | 38.6 | QAM256 | 28 |
29 | 362750000 | -7.1 | 37.6 | QAM256 | 29 |
30 | 370750000 | -7.1 | 38.6 | QAM256 | 30 |
31 | 378750000 | -7.3 | 38.6 | QAM256 | 31 |
32 | 386750000 | -7.4 | 38.6 | QAM256 | 32 |
33 | 394750000 | -7.3 | 38.6 | QAM256 | 33 |
34 | 402750000 | -7.4 | 37.6 | QAM256 | 34 |
35 | 410750000 | -7.3 | 38.6 | QAM256 | 35 |
36 | 418750000 | -7.1 | 37.6 | QAM256 | 36 |
on 19-01-2022 13:34
1gig packages do not use these downstream frequencies however these are out of spec and its likely your OFDM block is too. You should remove the attenuator and repost the readings. Also include the upstream and any information on profiles and OFDM.
Thank you
Jon
19-01-2022 13:50 - edited 19-01-2022 14:18
Thanks @VM-Jon
What is OFDM and how do I check that out. Same query on profiles? thanks
Are you saying remove the attenuator completely and get the numbers? I have a spare 10db one, guess that might be better.
Here is further info (still with 15db attenuator in place)
25 | Locked | 38.983261 | 0 | 0 |
6 | Locked | 37.636276 | 0 | 0 |
7 | Locked | 37.355988 | 0 | 0 |
8 | Locked | 37.636276 | 0 | 0 |
9 | Locked | 37.355988 | 0 | 0 |
10 | Locked | 37.636276 | 0 | 0 |
11 | Locked | 37.636276 | 0 | 0 |
12 | Locked | 37.636276 | 0 | 0 |
13 | Locked | 37.355988 | 0 | 0 |
14 | Locked | 36.609653 | 0 | 0 |
15 | Locked | 36.609653 | 0 | 0 |
16 | Locked | 37.355988 | 0 | 0 |
17 | Locked | 37.636276 | 0 | 0 |
18 | Locked | 37.636276 | 0 | 0 |
19 | Locked | 37.636276 | 0 | 0 |
20 | Locked | 37.636276 | 0 | 0 |
21 | Locked | 37.636276 | 0 | 0 |
22 | Locked | 37.636276 | 0 | 0 |
23 | Locked | 37.636276 | 0 | 0 |
24 | Locked | 38.605377 | 0 | 0 |
26 | Locked | 38.605377 | 0 | 0 |
27 | Locked | 38.605377 | 0 | 0 |
28 | Locked | 38.605377 | 0 | 0 |
29 | Locked | 37.636276 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.605377 | 0 | 0 |
32 | Locked | 38.605377 | 0 | 0 |
33 | Locked | 38.605377 | 0 | 0 |
34 | Locked | 37.636276 | 0 | 0 |
35 | Locked | 38.605377 | 0 | 0 |
36 | Locked | 37.636276 | 0 | 0 |
159 | 94 | 4K | 1840 | QAM4096 | 424 |
159 | Locked | 41 | -5.6 | 4075275249 | 0 |
1 | 60300000 | 41.3 | 5120 KSym/sec | 64QAM | 1 |
2 | 39400000 | 40.8 | 5120 KSym/sec | 64QAM | 4 |
3 | 46200000 | 40.8 | 5120 KSym/sec | 64QAM | 3 |
4 | 53700000 | 41.3 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_STDMA | 0 | 0 | 1 | 0 |
3 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 19-01-2022 14:44
Figures now WITHOUT any attenuator fitted:
25 | 330750000 | 9.9 | 39 | QAM256 | 25 |
6 | 178750000 | 8.1 | 38.6 | QAM256 | 6 |
7 | 186750000 | 7.8 | 38.6 | QAM256 | 7 |
8 | 194750000 | 7.6 | 38.6 | QAM256 | 8 |
9 | 202750000 | 7.7 | 38.6 | QAM256 | 9 |
10 | 210750000 | 7.5 | 38.6 | QAM256 | 10 |
11 | 218750000 | 7.2 | 38.6 | QAM256 | 11 |
12 | 226750000 | 6.8 | 38.6 | QAM256 | 12 |
13 | 234750000 | 6.3 | 38.6 | QAM256 | 13 |
14 | 242750000 | 6.1 | 37.6 | QAM256 | 14 |
15 | 250750000 | 6.9 | 38.6 | QAM256 | 15 |
16 | 258750000 | 7.7 | 38.6 | QAM256 | 16 |
17 | 266750000 | 7.9 | 39 | QAM256 | 17 |
18 | 274750000 | 8.1 | 38.6 | QAM256 | 18 |
19 | 282750000 | 8.1 | 38.6 | QAM256 | 19 |
20 | 290750000 | 8.1 | 38.6 | QAM256 | 20 |
21 | 298750000 | 8.7 | 39 | QAM256 | 21 |
22 | 306750000 | 9.4 | 39 | QAM256 | 22 |
23 | 314750000 | 9.7 | 39 | QAM256 | 23 |
24 | 322750000 | 9.8 | 39 | QAM256 | 24 |
26 | 338750000 | 9.5 | 39 | QAM256 | 26 |
27 | 346750000 | 9.1 | 39 | QAM256 | 27 |
28 | 354750000 | 8.6 | 39 | QAM256 | 28 |
29 | 362750000 | 8 | 39 | QAM256 | 29 |
30 | 370750000 | 8.1 | 39 | QAM256 | 30 |
31 | 378750000 | 8.3 | 39 | QAM256 | 31 |
32 | 386750000 | 8 | 39 | QAM256 | 32 |
33 | 394750000 | 7.7 | 40.4 | QAM256 | 33 |
34 | 402750000 | 7.5 | 39 | QAM256 | 34 |
35 | 410750000 | 7.9 | 39 | QAM256 | 35 |
36 | 418750000 | 8.3 | 38.6 | QAM256 | 36 |
3.0 Downstream channels
9 | Locked | 38.605377 | 0 | 0 |
10 | Locked | 38.605377 | 0 | 0 |
11 | Locked | 38.605377 | 6 | 0 |
12 | Locked | 38.605377 | 0 | 0 |
13 | Locked | 38.605377 | 0 | 0 |
14 | Locked | 37.636276 | 0 | 0 |
15 | Locked | 38.605377 | 0 | 0 |
16 | Locked | 38.605377 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.605377 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.605377 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.983261 | 0 | 0 |
32 | Locked | 38.983261 | 0 | 0 |
33 | Locked | 40.366287 | 0 | 0 |
34 | Locked | 38.983261 | 0 | 0 |
35 | Locked | 38.983261 | 0 | 0 |
36 | Locked | 38.605377 | 0 | 0 |
on 19-01-2022 14:46
3.1 Downstream channels
159 | Locked | 42 | 9.5 | 3590287 | 0 |
1 | 25800000 | 39.8 | 5120 KSym/sec | 64QAM | 6 |
2 | 32600000 | 40.3 | 5120 KSym/sec | 64QAM | 5 |
3 | 39400000 | 40.3 | 5120 KSym/sec | 64QAM | 4 |
4 | 46200000 | 40.3 | 5120 KSym/sec | 64QAM | 3 |
3.0 Upstream channels
2 | US_TYPE_STDMA | 0 | 0 | 0 | 0 |
on 19-01-2022 14:58
Figures with a 10db Attenuator Fitted:
25 | 330750000 | -0.3 | 39 | QAM256 | 25 |
6 | 178750000 | -1.7 | 38.6 | QAM256 | 6 |
7 | 186750000 | -1.9 | 38.6 | QAM256 | 7 |
8 | 194750000 | -2.1 | 37.9 | QAM256 | 8 |
9 | 202750000 | -2.3 | 37.6 | QAM256 | 9 |
10 | 210750000 | -2.3 | 39 | QAM256 | 10 |
11 | 218750000 | -2.5 | 39 | QAM256 | 11 |
12 | 226750000 | -2.8 | 37.6 | QAM256 | 12 |
13 | 234750000 | -3.7 | 37.6 | QAM256 | 13 |
14 | 242750000 | -3.9 | 37.6 | QAM256 | 14 |
15 | 250750000 | -2.9 | 37.6 | QAM256 | 15 |
16 | 258750000 | -2.2 | 38.6 | QAM256 | 16 |
17 | 266750000 | -2.1 | 38.6 | QAM256 | 17 |
18 | 274750000 | -2 | 38.6 | QAM256 | 18 |
19 | 282750000 | -1.9 | 39 | QAM256 | 19 |
20 | 290750000 | -1.8 | 39 | QAM256 | 20 |
21 | 298750000 | -1.5 | 38.6 | QAM256 | 21 |
22 | 306750000 | -0.9 | 39 | QAM256 | 22 |
23 | 314750000 | -0.5 | 39 | QAM256 | 23 |
24 | 322750000 | -0.2 | 38.6 | QAM256 | 24 |
26 | 338750000 | -1 | 38.6 | QAM256 | 26 |
27 | 346750000 | -1.3 | 39 | QAM256 | 27 |
28 | 354750000 | -1.5 | 38.6 | QAM256 | 28 |
29 | 362750000 | -2 | 39 | QAM256 | 29 |
30 | 370750000 | -2 | 39 | QAM256 | 30 |
31 | 378750000 | -2.1 | 38.6 | QAM256 | 31 |
32 | 386750000 | -2.3 | 39 | QAM256 | 32 |
33 | 394750000 | -2.2 | 39 | QAM256 | 33 |
34 | 402750000 | -2.3 | 38.6 | QAM256 | 34 |
35 | 410750000 | -2.2 | 39 | QAM256 | 35 |
36 | 418750000 | -1.9 | 38.6 | QAM256 | 36 |
8 | Locked | 37.935909 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 38.983261 | 8 | 0 |
12 | Locked | 37.636276 | 6 | 0 |
13 | Locked | 37.636276 | 2 | 0 |
15 | Locked | 37.636276 | 10 | 0 |
16 | Locked | 38.605377 | 9 | 0 |
17 | Locked | 38.605377 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
24 | Locked | 38.605377 | 1 | 0 |
30 | Locked | 38.983261 | 2 | 0 |
31 | Locked | 38.605377 | 2 | 0 |
32 | Locked | 38.983261 | 4 | 0 |
33 | Locked | 38.983261 | 4 | 0 |
34 | Locked | 38.605377 | 4 | 0 |
36 | Locked | 38.605377 | 1 | 0 |
on 19-01-2022 14:59
159 | Locked | 42 | -0.4 | 2368867 | 0 |
1 | 25800000 | 40.3 | 5120 KSym/sec | 64QAM | 6 |
on 19-01-2022 15:42
The 10dB stats look fairly good, but I think you probably only need a 6dB forward path attenuator. This would probably put you in the optimum power range.
on 19-01-2022 15:47
Thanks.
As I'm using DOCSIS 3.1, should I ignore the 3.0 figures?
Is the number I'm interested in the one relating to "PLC Power (dBmV)" in the 3.1 download section?
If so, does the same range principle apply of -6 to +10 (or ideally -3 to +8 to allows for seasonal temp variations in resistance)?
I still don't know what OFDM Block is and how to find the readings? Also, the same for the requested "Profile" info?
Do VM post out 6bd attenuators?
on 19-01-2022 16:51
The reason I ask is that my DOCSIS 3.1 stats are:
- 15db attenuator:
- 10db attenuator:
159 | Locked | 42 | -0.4 | 46824194 | 0 |
No Attenuator:
So if the objective is to get the DOCSIS 3.1 PLC Power (dBmV) to as near to zero as possible, then for DOCSIS 3.1 the 10dB attenuator does this. However, for DOCSIS 3.0 channels (which I don't think I'm using) then I can see a 6dB would be better.
Do attenuators also impact upstream levels?
