on 18-06-2022 13:12
Hi all. I have just had a replacement hub 3 modem fitted and this has a different network name. I can log in to all of my appliances except for 1. This is the monitoring system for my solar panels. I therefore need to change the details in the wifi dongle on the panels inverter. No one at virgin has been able to assist me so far. Anyone with solar panels will know how essential it is to be able do this and I was hoping that one of you brilliant panelists might be able to help.Thanks
Answered! Go to Answer
18-06-2022 15:00 - edited 18-06-2022 15:02
@ronjo94 It may be easier just to change the network name (SSID) and password on the replacement Hub3 to the ones used on the old Hub3. That way you don't need to change the solar panel settings.
You will of course need to change the other connected devices back to the old settings.
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Please read the FAQs
on 18-06-2022 14:38
A quick scan of YouTube suggests you do this through the relevant manufacturer app.
Alternatively you could get a cheap WiFi router, stick the hub in modem mode and rename the current hub Ssid and password back to the old one.
on 18-06-2022 16:45
on 18-06-2022 16:51
