on 02-03-2021 16:21
hello everybody,
since about one week ago my broadband started to disconnect frequently. I tried to reset everything to factory settings but di not work. I do not understand if is my problem or it is from virgin media.
02/03/2021 11:12:9 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2021 19:13:12 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2021 18:47:17 | notice | Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2021 18:39:25 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2021 18:39:17 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2021 18:38:57 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/02/2021 08:34:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/02/2021 11:53:6 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/02/2021 20:34:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/02/2021 08:12:24 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/02/2021 08:34:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/02/2021 09:40:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2021 20:34:56 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2021 23:22:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2021 13:29:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2021 13:29:55 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2021 13:29:55 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2021 13:29:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2021 13:29:51 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 21-08-2021 10:25
So engineers have been out again.
We now have a 10db attenuator BEFORE the splitter for the Hub and v-box.
So upstream and downstream voltages are now lower, however, We still get this t3 ranging error and its always-on channel 1 of the bonded upstream connections.
Had a field manager tell me that these dropouts are clearly a result of my own equipment and that it's because I'm using the hub in Modem mode.....
Can we actually get someone to investigate this? if not I'm going to have to push for money off the bill..... this has been going on for months now and its horrendously inconvenient with 3 people working from home.
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 202750000 | 3.5 | 37 | 256 qam | 9 |
2 | 138750000 | 3 | 36 | 256 qam | 1 |
3 | 146750000 | 3 | 36 | 256 qam | 2 |
4 | 154750000 | 3 | 36 | 256 qam | 3 |
5 | 162750000 | 3.5 | 37 | 256 qam | 4 |
6 | 170750000 | 3.2 | 37 | 256 qam | 5 |
7 | 178750000 | 3.2 | 37 | 256 qam | 6 |
8 | 186750000 | 3.2 | 37 | 256 qam | 7 |
9 | 194750000 | 3.5 | 37 | 256 qam | 8 |
10 | 210750000 | 3.2 | 37 | 256 qam | 10 |
11 | 218750000 | 3.2 | 37 | 256 qam | 11 |
12 | 226750000 | 3.2 | 37 | 256 qam | 12 |
13 | 234750000 | 3.2 | 37 | 256 qam | 13 |
14 | 242750000 | 2.9 | 37 | 256 qam | 14 |
15 | 250750000 | 2.9 | 37 | 256 qam | 15 |
16 | 258750000 | 3 | 37 | 256 qam | 16 |
17 | 266750000 | 3.2 | 37 | 256 qam | 17 |
18 | 274750000 | 3 | 37 | 256 qam | 18 |
19 | 282750000 | 3.7 | 37 | 256 qam | 19 |
20 | 290750000 | 4 | 37 | 256 qam | 20 |
21 | 298750000 | 4.4 | 37 | 256 qam | 21 |
22 | 306750000 | 4.5 | 37 | 256 qam | 22 |
23 | 314750000 | 4.9 | 37 | 256 qam | 23 |
24 | 322750000 | 5 | 37 | 256 qam | 24 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 39400044 | 43.3 | 5120 | 64 qam | 2 |
2 | 46200000 | 42.3 | 5120 | 64 qam | 1 |
3 | 32600000 | 42.5 | 5120 | 64 qam | 3 |
4 | 25800000 | 41.5 | 5120 | 16 qam | 4 |
Upstream bonded channels | |||||
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
Time | Priority | Description |
21/08/2021 05:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 10:10 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 10:10 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 10:10 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 09:37 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 09:36 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 09:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 09:36 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 09:31 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 09:25 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
16/08/2021 09:49 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.0; |
on 23-08-2021 10:48
Hi dmxking512,
Thanks for posting on our community forums. Sorry to hear that you're still experiencing ongoing issues with our services, even though an engineer has already visited.
Your post stated that you have already spoken to an area filed manager, who has explained the reasons why this problem is occurring.
We can ask for a 2nd opinion on this for you, however if the area field manager has already given his advice, we may not be able to book in another technician.
We have checked your account remotely this morning; from the details you have provided from your community profile and there are no issues at all showing that could be causing this issue. All you power levels are within specification; you have no SNR issues affecting you or area faults.
As you posted on Saturday, can we ask how your services have been over the weekend?
Kind regards Jodi.
on 23-08-2021 10:55
Service dropped out yesterday at around 3pm.
I don't disagree that your field engineers have looked into the hardware here and the pillar in the street. but the fact of the matter is that the connection drops.... regularly and at inconsistent times. They have not explained what's causing it. They have only given potential reasons.
the engineer mentioned that it could be a spike from the cabinet. is there anything we can put in place to monitor any fluctuations in power?
on 25-08-2021 11:25
Hi dmxking512,
Thank you for reaching back out tom us, so we can get a better idea of what is happening please set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any network dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with us. Make sure you uncheck the “ignore ping from WAN side” box in the settings if you see a wall of "red" - note it will take an hour or two to start seeing a sensible picture. please run this for 72 hours and post the results here so we can have a further look into this for you.
Kind regards
Paul.
