on 04-01-2021 09:19
What’s best way off getting WiFi in my man cave which is about 30m away from my router ,
on 04-01-2021 09:59
run an ethernet cable from the hub to the mancave and connect a wireless access point to it.
on 04-01-2021 10:03
Hi thanks for reply what do u mean by a wireless access point
on 04-01-2021 10:16
on 04-01-2021 10:20
Ok so if I , run an Ethernet cable from my router to this it will work ,will it be same network or different
on 04-01-2021 10:28
on 19-01-2022 18:55
Good evening I have a mancave around 20m from router ,how can I improve my signal in there ,without running an Ethernet cable as its a no go
on 19-01-2022 19:14
on 19-01-2022 19:18
Hi my router is in the lounge and I've a mancave in garden about 20m or so from the router ,would have to go through 3 walls just to get it outside
19-01-2022 19:26 - edited 19-01-2022 19:27
You mean your lounge has no exterior walls (or windows)?
If it does.... you only need to get it outside through 1 hole. Could drill it through the window frame. Or possibly feed it backwards through the same hole as the VM cable comes in from outside - using cable with no teminator ends fitted of course. Or are their any "airbricks" in the property? Our 1930's semi has several and I could easily run cable from my router outside through that. Or lift a floorboard and run it out that way.
Then as long as you use exterior grade Cat6a cable you can just tack it to the outside walls, garden fences, or in a trench in the flower bed or garden, etc.
