on 18-04-2024 12:08
Sorry for the vague title, but I don't really know what the issue is and it's driving me mad! I've had the HUB 5 with 1 additional 'Pod' and it's been fantastic, no issues at all. Then all of a sudden this week something changed that has interfered with some of my WiFi connected devices. Problem is I don't know what has changed or how to fix it...
I still have WiFi access and ethernet access on all my devices, so it is not a connectivity problem, but some of the devices are now malfunctioning. For example my Ring Doorbell shows a strong wifi signal, but will not connect to live view, will not record motion alerts to the cloud, and will not send doorbell push notifications - but it is connected to WiFi and the hourly 'snapshot' image IS uploaded to the cloud.
Similarly with my PodPoint, scheduling is no longer working and the app insists the Podpoint is not connected to the internet and can't communicate with it, and forces me into WiFi setup mode. But when I do the setup on the PodPoint itself confirms it is connected to the internet - PodPoint support also confirm they can see it is connected to the network. So it is not a connection problem, it's like Virgin is suddenly blocking part of the signal getting through...
I've tried searching for answers but I can't find any, there is another user that says they've lost access to 'Slack' since Monday on their HUB 5, I've no idea what that is but that's about the same time my connections went wonky...
It feels like Virgin have done a config change to block a port or apply a VPN or something that is causing connection issues, but I don't know what. So any technical help would be very welcome...
I've tried resetting the router, I've tried setting up a guest wifi and connecting to that, I've tried resetting and reinstalling all the apps of the affected WiFi devices, but nothing is working. The config menu of the HUB 5 is very limited so there isn't really much I can try. I tried disabling the 'Smart' feature for the WiFi management but that didn't work either. Something must have changed at the Virgin end this week - is there a way to know what?
Additionally I tried the network diagnostic in the config menu and that unhelpfully said 'Your home network has a few problems' but with no explanation what those problems were or how they can be fix... The VM Connect app is also showing 'Unknown' for all the connections and 'can't calculate device's health' so that is no use to me either...
Any ideas? I'm willing to try anything (short of having to buy a new router!)
Answered! Go to Answer
on 18-04-2024 16:55
Hi WA5 area here, same problem we have 3x ring devices all refusing to connect via live view, started playing up a couple of days ago before that were working perfectly.
is there any word from VM when they will be fixing what ever is causing this?
on 18-04-2024 18:26
I'm in WA2 and just found this thread. My ring doorbell and ring app have been driving me mad. Also got kicked out of Hive last night and had to reinstall that. At least now I know it's not ring. The big problem is those shiesters at VM who I pay £60/month to and the fact they won't have any drive to sort this out.
on 19-04-2024 09:14
Update, my three devices appear to be working normally this morning, I live in the WA5 area.
on 19-04-2024 09:34
Yes, things seems to have improved today regarding Internet connections to certain websites. Like you, I had been having issues since Monday or Tuesday.
on 19-04-2024 18:08
Mine seems to be back working fine again now in WA2.
