on 03-10-2022 11:08
Hi there,
My VPN for work keeps dropping and its only from home, which I moved into 2 weeks ago. All other locations are fine with the VPN.
1 | 139000000 | 7.3 | 37 | 256 qam | 1 |
2 | 147000000 | 7.3 | 38 | 256 qam | 2 |
3 | 155000000 | 7.5 | 38 | 256 qam | 3 |
4 | 163000000 | 7.4 | 38 | 256 qam | 4 |
5 | 171000000 | 7.4 | 37 | 256 qam | 5 |
6 | 179000000 | 7.3 | 37 | 256 qam | 6 |
7 | 187000000 | 7.5 | 37 | 256 qam | 7 |
8 | 195000000 | 7.4 | 37 | 256 qam | 8 |
9 | 203000000 | 7.1 | 37 | 256 qam | 9 |
10 | 211000000 | 6.8 | 37 | 256 qam | 10 |
11 | 219000000 | 6.5 | 38 | 256 qam | 11 |
12 | 227000000 | 6.3 | 37 | 256 qam | 12 |
13 | 235000000 | 6.3 | 38 | 256 qam | 13 |
14 | 243000000 | 6.8 | 38 | 256 qam | 14 |
15 | 251000000 | 7.3 | 38 | 256 qam | 15 |
16 | 259000000 | 7.5 | 38 | 256 qam | 16 |
17 | 267000000 | 7.5 | 38 | 256 qam | 17 |
18 | 275000000 | 7.5 | 38 | 256 qam | 18 |
19 | 283000000 | 7.5 | 38 | 256 qam | 19 |
20 | 291000000 | 7.5 | 38 | 256 qam | 20 |
21 | 299000000 | 7.5 | 38 | 256 qam | 21 |
22 | 307000000 | 7.5 | 38 | 256 qam | 22 |
23 | 315000000 | 7.9 | 38 | 256 qam | 23 |
24 | 323000000 | 8 | 38 | 256 qam | 24 |
1 | Locked | 37.6 | 187 | 0 |
2 | Locked | 38.6 | 79 | 0 |
3 | Locked | 38.9 | 13 | 0 |
4 | Locked | 38.6 | 26 | 0 |
5 | Locked | 37.6 | 16 | 0 |
6 | Locked | 37.6 | 45 | 0 |
7 | Locked | 37.6 | 59 | 0 |
8 | Locked | 37.6 | 59 | 0 |
9 | Locked | 37.6 | 61 | 0 |
10 | Locked | 37.6 | 84 | 0 |
11 | Locked | 38.6 | 83 | 0 |
12 | Locked | 37.6 | 75 | 0 |
13 | Locked | 38.6 | 71 | 0 |
14 | Locked | 38.6 | 60 | 0 |
15 | Locked | 38.9 | 53 | 0 |
16 | Locked | 38.9 | 53 | 0 |
17 | Locked | 38.9 | 65 | 0 |
18 | Locked | 38.9 | 50 | 0 |
19 | Locked | 38.9 | 69 | 0 |
20 | Locked | 38.9 | 60 | 0 |
21 | Locked | 38.6 | 69 | 0 |
22 | Locked | 38.9 | 73 | 0 |
23 | Locked | 38.9 | 62 | 0 |
24 | Locked | 38.9 | 91 | 0 |
1 | 23600000 | 45.8 | 5120 | 64 qam | 10 |
2 | 30100000 | 45.5 | 5120 | 64 qam | 8 |
3 | 49600000 | 45 | 5120 | 64 qam | 5 |
4 | 36600000 | 45 | 5120 | 64 qam | 7 |
5 | 43100000 | 44.8 | 5120 | 64 qam | 6 |
If anyone can see anything that might be causing an issue I'd really appreciate it
on 03-10-2022 11:10
on 03-10-2022 11:28
on 03-10-2022 11:36
I dont have a LAN cable for my device so would not easy to test.
I've been pinging with another device to 8.8.8.8 and it seems pretty good with the odd slow ping but not at the same time as when the VPN drops, so don't think that's related.
03-10-2022 11:44 - edited 03-10-2022 11:48
But its easy to get a cable to test.
https://www.amazon.co.uk/dp/B093WVS6TG/?coliid=I1R1019O53YUZE&colid=1BZ90MP5AMKFF&psc=1&ref_=lv_ov_l...
Or you could jump right to a new router with 1Gb ports and put hub in modem mode for wifi.
on 03-10-2022 11:49
sorry - my device doesnt have an RJ45 port, should have made that clearer.
Do you know if there's anything wrong with the numbers I posted? I've no idea what a good SNR would be. doesnt look from the logs that I'm getting any disconnects.
Is there a test I could run from a device that is fine to see if I get packet loss or latency over a long period of time (say 30 minutes) that you'd recommend?
on 03-10-2022 11:55
@owensteam wrote:Do you know if there's anything wrong with the numbers I posted? I've no idea what a good SNR would be. doesnt look from the logs that I'm getting any disconnects.
Looks good you say you have done a ping test and thats fine.
Problem is likely wifi with the hub a better wifi router will help.
you can run a custom test here
Packet Loss Test - Test Your Connection Online | DeviceTests
Network Packet Size = 900
Sending Frequency = 300
Test Length = 60
Maximum Delay Between Packets =1
on 04-10-2022 14:34
Everything is normal, not sure why this vpn is dropping. Makes no sense
on 04-10-2022 14:42
on 11-10-2022 16:42
Hello,
I have an adapter and have set to airplane mode so it’s just the wired comnection. Exactly the same issue still happening.
